Oil pan help no clear answer !
What oil pan will fit our car ? Outlander ? Eclipse ? They both look similar to ours help I'm leaking oil ! If any one knows please help ! I've already expoxy a couple times now it's bad ! If you know post link to the pan ! Thank you
that says it only fits the eclipse which is a different part number than the Lancer Ralliart...however the engine block should be identical, so there's no reason this shouldn't bolt up...that being said, I'm not guaranteeing anything...
Im going to order it ill keep you posted !
The 2003 eclipse oil pan is exactly the same pan 👌. Just installed
redlinedrift
28
Nov 11, 2011 03:16 PM
