Firewall hole?
Old Oct 6, 2004 | 05:39 AM
bruce988jl's Avatar
Firewall hole?
Hey i was wondering if anyone found out where the hole in the firewall? I need to run a wire for my interior lights and amp and i have no clue where the hole in the firewall is. Any help would be greatly welcome, thanks
-Lee
Old Oct 6, 2004 | 09:17 AM
RaLLi's Avatar
-Lee
Its under the glovebox, kinda to the left. There is a thick black hose going through. use a pen or screw driver to wedge in there so you can fit a wire through, right along with the thick black hose.
Thats the way my dealer did it for me. It was $32. Try it yourself, because that how they did it.
Old Oct 6, 2004 | 12:48 PM
95TsiAWD's Avatar
There's also one on the driver's side under the dash where the wires run through, I got a coat hanger in there but then when pulling it back got the hanger stuck and had to cut it off and leave it up inside the fender somewhere so use a real wire puller
Old Oct 6, 2004 | 12:51 PM
lookslikeanevo's Avatar
theres should also be one right...behind the passenger side strut the grommet is rather easy to take out
Old Oct 6, 2004 | 07:05 PM
otter's Avatar
EvoM Administrator
When I ran my amp power wire, I found a great place to drill a hole, directly below where the clutch pedal bottoms out. There's nothing near it on the other side of the firewall (though don't take my word for it, CHECK BEFORE YOU DRILL) and it's easy to get to from underneath the car when it comes time to seal it up.
