When Does MIVEC Kick In...?
Old Sep 21, 2004 | 01:49 PM
Arithmetic's Avatar
Exclamation When Does MIVEC Kick In...?
So all these variable valve timing things like the famous, but over-rated VTECand I-VTEC that you feel in the higher RPM's, and the VVTL-I on the celica that you feel on the higher RPM's, so where does MIVEC stand? I know it works in the lower and mid RPM's, but is it like the civic or celica? The car has a nice grunt and low and mid, is that MIVEC? Just wondering, cuz I wanna yell out MIVEC!!! as I pass a sI
Old Sep 21, 2004 | 02:00 PM
PDXRalliArt's Avatar
MIVEC in detail
That should help.
Old Sep 21, 2004 | 02:30 PM
blk-majik's Avatar
nice, first time i have seen this doc. good find!
Old Sep 21, 2004 | 02:42 PM
captain150's Avatar
Short answer, 3500rpm.
Excellent article though! I never knew a few things.
So before 3500, the 2 intake valves are opening at different lift for high swirl in the combustion chamber. After 3500, the T lever that is being moved by the center lobe is engaged and both valves open more and for a longer period of time. A very neat system.
Old Sep 21, 2004 | 03:24 PM
AlkalineTrio124's Avatar
This is awesome my brother & all his VTEC talk... He's always like what's MIVEC? & I kind of b.s. my way through it... finally some good detailed description... i'm just going to quote the whole thing to him...
Old Sep 21, 2004 | 05:20 PM
captain150's Avatar
Variable valve timing isn't "all that"
There have been high lift cams since, forever. You know a car has a cam like that when it idles like poop. You know a car has a mild cam when it has a smooth idle. What variable valve timing does is allow a car to have a mild cam (at idle/low rpm) for good fuel economy and smooth running and also allow it to have high lift/duration (at high rpm) for maximum air/fuel flow and power. Prior to VTEC, you could have one, or the other. Now we can have both.
It's not like a VTEC/MIVEC engine is far superior to anything without variable valve timing. But it helps economy (at low rpm) and power (at high rpm).
Old Sep 21, 2004 | 05:49 PM
Nad1370's Avatar
I always thought MIVEC was on all the time ( except maybe at idle ) . Adjusting at every rpm for omptimum power and economy.
Old Sep 21, 2004 | 07:19 PM
blk-majik's Avatar
MIVEC uses 2 cam profiles. The engine switches to the higher cam at about 3500rpm. its not constantly dynamic or anything. just 2 profiles.
Old Sep 21, 2004 | 07:25 PM
insomniac_evo's Avatar
the dood who made vtec moved to mitsu after 10 years in honda... :P
Old Sep 21, 2004 | 08:35 PM
I'm just happy that I can explain it better to people I talk about cars with!
Old Sep 21, 2004 | 08:36 PM
Old Sep 21, 2004 | 08:37 PM
captain150's Avatar
Nope, there's 3 cam profiles. The low lift and medium lift profiles are both used from idle-3500rpm. One valve is opened a little and the other is opened medium ways. After 3500rpm, the T arm engages and both valves operate on the high lift lobe. Below 3500rpm is for economy, above 3500rpm is for power/flow.
Old Sep 21, 2004 | 11:41 PM
Arithmetic's Avatar
my adobe keeps stalling on me, so i cant read that dam doc. I still would like to read a comprehensive report on it, im a reader nut.
Old Sep 22, 2004 | 05:39 AM
blk-majik's Avatar
try this:
http://216.239.51.104/search?q=cache..._08.pdf+&hl=en
Old Sep 23, 2004 | 12:46 PM
WRCRalliArt04's Avatar
Also it should be noted that Mivec only operates these new valve timings on the INTAKE valves...where VTEC uses both Intake and Exhaust valves. I thought this should be said. But knowing how ****ty my buddy's 04' iVTEC SI is...I'm not sure I would be impressed by this new info... :P
