When Does MIVEC Kick In...?
Old Oct 3, 2004 | 08:12 PM
  #31
GPTourer's Avatar
Yes, but I have seen it done on a high revving N/A, road course, high compression car where it would benefit to be on big cam all the time.
Old Oct 3, 2004 | 08:15 PM
  #32
Blaze6257's Avatar
well there is a skunk2 400HP+ all motor RSX, i believe they just lower the vtec, to give it the effect of higher profile cams. or they just use new cam, all ireally know about that car is that they use the K-pro ECU which is fully programmable and basically i could lower my vtec point to 2000rpm and still be fine, but not as a daily driver
Old Oct 4, 2004 | 04:29 PM
  #33
Canadian Canuck's Avatar
I just found the Japan version of the Lancer RA comes stock with HID's I'm getting pricing to see what they will cost, as you will have to change the stock Headlamp housing.
Old Oct 4, 2004 | 04:30 PM
  #34
Blaze6257's Avatar
slightly off topic?
Old Oct 4, 2004 | 04:47 PM
  #35
turbonutter's Avatar
Originally Posted by Blaze6257
slightly off topic?
Nah.... its' completely on-topic, because you know HID's can greatly affect your variable valve timing system....
Old Oct 6, 2004 | 11:22 PM
  #36
raliart's Avatar
here is my question, is it rpm activated and throttle position, or just rpm activated i beleive its rpm activated cause i get terrible gas mileage above 3500rpm what i would ask is what if you drive at exactly 3500rpm will it switch on and off or just stay on or off what gives?
Old Oct 7, 2004 | 01:26 AM
  #37
Arithmetic's Avatar
3500rpm, mivec kicks in, so if you stay below that, ur gas will be the higher 20's mpg, anything above mivec and ull get ****ty gas, trust me... i stay in mivec from time to time and my gas sucks.
As far as it switchin on and off, i dont think it continueous like the specV, or how long it rides to (like to redline or so?)
moparfan
Mar 18, 2021 10:28 PM
Girlie
Jun 6, 2019 11:11 PM
dudical26
Feb 12, 2013 08:26 AM
hackish
15
Oct 2, 2009 08:01 AM
Arithmetic
Nov 21, 2004 06:55 PM
