mivec and vtec?
Old Dec 26, 2004 | 03:51 PM
Arithmetic's Avatar
^^^ get a MIVEC controller and tune that RA! People that have tuned MIVEC on there 3000gt have got GREAT RESULTS and IMPROVED HP/TRQ and GAS!
Old Dec 26, 2004 | 06:39 PM
otter's Avatar
EvoM Administrator
Does anyone know if the J-spec MIVEC controllers (such as the ones for the 3000GT) will work on the US version, or is it pure speculation at this point?
Old Dec 26, 2004 | 08:49 PM
reimundo's Avatar
i don't think nobody knows because of the three stage mivec settings. does anybody knows the name of the mivec controlers? because i will try it to see if it will work.
Old Dec 27, 2004 | 06:44 AM
Myszkewicz's Avatar
Originally Posted by otter
Personally, I'd just like to have a way to install a switch to turn MIVEC off when cruising at highway speeds.
That would only work if you don't mind staring at the CEL. Unfortunately, the ECU checks to see if the Mivec turns off below 3k rpm and turns on above 4k.
All it would take is a box that takes rpm readings, sends 0v to the right pin on the ECU below 3500rpm and +12v above 3500, and lets you switch on or off the ground from the oil control valve. That's a little beyond my electrical abilities.
Old Dec 27, 2004 | 09:22 AM
sillypuddy's Avatar
it's not that simple.. you should read my thread about VTEC/MIVEC controllers and how they can't really get the correct fuel maps at the correct time..
they are pretty much unless compare to a good standalone
-joe
Old Dec 27, 2004 | 11:34 PM
reimundo's Avatar
does anybody know if the mivec could be controled ?
Old Dec 28, 2004 | 04:56 PM
Widebody Lancer's Avatar
VTEC is from 4600 - 5400 yes on most USDM engines its 5200 rpm on some jdm motors its 4600 all depends on the motor...
Tory
Old Dec 28, 2004 | 06:16 PM
hank's Avatar
Originally Posted by Widebody Lancer
just like lowering a vtec point its useless, vtec points lowering are dumb unless u have a different cam that performes at a lower rpm point.
Mivec is completly differnent in every aspect. both very nice systems with pros and cons to each
Tory
Guess thats why Realtime Racing moves the switchover down to 4k on a stock cam, cause their "stupid"
Old Dec 28, 2004 | 06:21 PM
sillypuddy's Avatar
on my 99 accord, i moved the vtec engagement to 3500 rpm, tuned the fuel maps and gain 10hp.. so it's not STUPID as stated
the switch over area's fuel map had issues as stated.. otherwise it runs great
-joe
Old Dec 28, 2004 | 06:27 PM
XRS's Avatar
XRS
Originally Posted by Jadiem
i know my old Field Vtec controller said it was Mivec compatible too...
That Vtec controller is compatible with Mivec. But 4G92 Mivec engines and later. These engines had the same setup for variable valve timing as Honda's Vtec. Does not work with the new Mivec because of the three valve profiles like the RSX i-Vtec.
Old Dec 28, 2004 | 06:29 PM
hank's Avatar
Down here we have this thing called sarcasm. My point for those who have never been in the pressence of sarcasm is that a very sucessfull race team Realtime racing has been lowering the vtec switching point for years.
Old Dec 29, 2004 | 04:13 PM
Ever expearience of lower vtec ive had was useless and lost a lot of tourque. this im talking on a stock motor providing you have intake maybe a nice exhaust i couldnt tell you im just talking on a stock ITR.
Tory
Old Jul 16, 2005 | 10:46 AM
Gomez_MR's Avatar
I really don't know about the Ralliarts that are out there but. I'm guess your MIVEC X-over would probably in the 4800 + range since the car redlines 6500. Yes you can lower the MIVEC point but the car will need to be tuned. To low of a MIVEC point will affect performance unless you have a cam that'll compensate for the lowered MIVEC X-over. As for Honda's VTEC It doesn't X-over until 5400+. In 5th gear until your at 95MPH you won't cross into VTEC. You can lower it lower but you need a cam and a VTEC or for MIVEC, a MIVEC controller. A good one that I know will work is the Fields VAFC which was meant for VTEC and MIVEC. BTW MIVEC and VTEC does not consume that much more gas. What consumes more gas is the RPM that you're shifting at.
Old Jul 16, 2005 | 01:25 PM
BensLancer's Avatar
That would be nice!!!!!!!
Old Jul 18, 2005 | 06:00 AM
sillypuddy's Avatar
i love how the honda fan boys think that intake/header/exhaust/port and polish/vtec controller will magically shave 3 FULL SECONDS off their 1/4 mile
you be lucky to shave 1.5 to 2 seconds guy
-joe
