mivec and vtec?
Old Jul 18, 2005 | 08:12 AM
  #31
Eclipse2Lancer's Avatar
Originally Posted by Gomez_MR
I really don't know about the Ralliarts that are out there but. I'm guess your MIVEC X-over would probably in the 4800 + range since the car redlines 6500. Yes you can lower the MIVEC point but the car will need to be tuned. To low of a MIVEC point will affect performance unless you have a cam that'll compensate for the lowered MIVEC X-over. As for Honda's VTEC It doesn't X-over until 5400+. In 5th gear until your at 95MPH you won't cross into VTEC. You can lower it lower but you need a cam and a VTEC or for MIVEC, a MIVEC controller. A good one that I know will work is the Fields VAFC which was meant for VTEC and MIVEC. BTW MIVEC and VTEC does not consume that much more gas. What consumes more gas is the RPM that you're shifting at.
MIVEC switch is at 3500....already pretty low. No one makes any aftermarket cams for the Ralliart motor (that I know of), so messing with the MIVEC point is pointless IMO, unless you are turning the thing into a full time race car.
Old Jul 18, 2005 | 11:44 AM
  #32
PR_Mivec's Avatar
Originally Posted by otter
Does anyone know if the J-spec MIVEC controllers (such as the ones for the 3000GT) will work on the US version, or is it pure speculation at this point?
as of today.. no
not one has work yet
