Gtech-Pro?
Old Jan 15, 2005 | 01:03 PM
ralliart86's Avatar
Gtech-Pro?
anyone have one of these installed in their RA or other cars? ive been looking at them and they seem pretty cool... just wondering if anyone could give me some feedback if they have them or have used them... thanks
Old Jan 15, 2005 | 04:08 PM
Blaze6257's Avatar
used one and have played with it dosent work that well if not tuned right...IMO dont like it
i would suggest getting a RacerDataDisplay R900($179.00) or the RacerDataDisplay R900e($229.00) its alot better connects to the OBDII port and must be configured too...but works better and has alot more features...
if you want specs on it or want to know where to get one let me know...i can tell you more too
Old Jan 15, 2005 | 06:50 PM
ralliart86's Avatar
yeah could you give me a website or something... that sounds interesting
thanks
Old Jan 15, 2005 | 06:54 PM
kingkyle's Avatar
I use the belltronics vector FX..... its very accurate. Ive timed many cars and its right on target with all the numbers you see in the mag's. I think i payed $180
Old Jan 15, 2005 | 06:56 PM
sillypuddy's Avatar
http://www.brockwayengineering.com/index.html
Old Jan 15, 2005 | 07:02 PM
Blaze6257's Avatar
there you go ... i got the prices from another forum/part store those are shipped prices...if your really intrested PM me and ill get you know...so i dont anger people on here advertising another forum
Old Jan 15, 2005 | 07:05 PM
Blaze6257's Avatar
after browsing trough their site there are only three autorized dealers...on of them is where i suggest you get it from...can you guess which one of those sites it is?
Old Jan 15, 2005 | 07:18 PM
blk-majik's Avatar
where is the obd2 connection in our car? is it the empty plug under the dash just below the steering wheel? maybe a little to the center. looks like a molex connector. 16 pin or something. is that it?
Old Jan 15, 2005 | 08:27 PM
ralliart86's Avatar
that looks cool... so unlike the gtech where you have to enter vehicle weight and stuff to calibrate the r900 just goes directly into the ecu
Old Jan 15, 2005 | 08:40 PM
Ralliart@PDX's Avatar
What make this product anything like the G-tech pro? G-tech pro with free upgrade to the g-tech rr model, is for a different use than this thing is. I could see if you only wanted 0-60? did i miss somthing from the website?.
Old Jan 16, 2005 | 06:50 PM
sillypuddy's Avatar
you know.. all this does is show you the values the ecu sees from the "stock" sensors.. it doesn't do anything else
you can already get a cable that does this with the palm pilot for way less AND you get data log
gtech pro is a different thing than this
-joe
Old Jan 17, 2005 | 07:52 PM
Blaze6257's Avatar
http://forums.clubrsx.com/showthread.php?t=205495
^ heres a review from ClubRSX
but yeah the two are slightly differant. but the 900e will do some thing the gtech will.
you could get a cheepo pda or what ever and then get the PDA dyno thing and datalog with that...but its not the same as the gtech or the 900. even if you datalog what are you really going to do? you cant tune it with the pda dyno because its just reading settings too.
either way. gtech usually gets mixed results. most people say its not worth it
Old Jan 18, 2005 | 09:00 AM
sillypuddy's Avatar
blaze, you can't tune with gtech pro or this thing EITHER..
-joe
Old Jan 18, 2005 | 09:53 AM
I currently own a g-tech pro with the RR upgrade, after takeing the time to read online and set it up correctly it is very accurate. Most people just want something to plug in and go requiring no reading or setup! thats justnot possible even if you spend $10,000 on data acc. system or a dyno. I 've have a guy that comes into my work with a 2004 ss silverado and he gets results in 1/4 that are dead on and very consistent. He showed me 10 passes @ the strip that were all almost dead on with his time slips. Shows me after inital setup they work excellent? Just my 2 cents though!
Old Jan 18, 2005 | 11:22 AM
Blaze6257's Avatar
-joe
hopefully i didnt type that i could...because i know you cant. it just reads info and displays it...sorry if i did
