O2 sensor [again!]
Old Feb 23, 2005 | 10:21 PM
pocoRA's Avatar
that's reallllllllyy good news, how hard would you say this was for you to do? and how long does it take?
Old Feb 23, 2005 | 11:00 PM
wiggle1r's Avatar
If you could please keep on updating us on this fix, hopefully it will work so I can get a downpipe without worrying about my CEL and crap. I really hope this works so I can start my modding again. Thanks for all your info thus far
Old Feb 24, 2005 | 11:24 AM
reTro's Avatar
As long as you have a good drill bit, I'd say it takes 1min to drill the hole. Then just drive your car up some ramps or be ghetto like me and park it half-way on the street/driveway so you can get under it. It takes another 5min(?) to unscrew and replace with the foulers. That's it!!! Real easy.
Old Feb 24, 2005 | 07:42 PM
MiVecJohn's Avatar
you know one you think about it you dont really need to screw them both... i only have 1 in one of the cars and works fine
Old Feb 24, 2005 | 09:25 PM
mitsubishimanny's Avatar
it will come back. i tried it with 1 for a week. you MUST use 2.
Old Mar 7, 2005 | 11:16 AM
reTro's Avatar
I just hit 2,000 miles today on the CEL fix with NO light. Damn I drive a lot!!!
Old Mar 15, 2005 | 01:55 PM
reTro's Avatar
BAD news guys... I just hit 3,200 miles on the CEL fix, and my light came on today!!!
I'm going to reset and see if I can go another few thousand. At least it's better than the 100-300 miles I was getting without the fix.
Old Mar 16, 2005 | 12:18 AM
amg_dragon's Avatar
That's funny (well not ha-ha funny) but I was looking through a friends JEG'S catalog and guess what they had for sale. A O2 sensor simulator! They didn't have a Mitsu specific one just a "imports" but it was around $40 and it looked like a plug in so you wouldn't have to cut/drill anything like that. I'm not positive that it will work on ours but I figured I'd throw it out there anyways in case someone wants to follow up on it. I don't have any plans to go catless on my RA anytime soon anyway.
Old Mar 28, 2005 | 10:30 PM
reTro's Avatar
Ok, this is weird. After about 50 more miles, the light went back off and now I'm at 3,800 miles with NO CEL?!
Old Mar 28, 2005 | 10:40 PM
did u try using both yet?
Old Mar 28, 2005 | 11:14 PM
amg_dragon's Avatar
$46 at jegs and you can get a Caspers 02 simulator for imports with 1 sensor (yes I know we have 2 but you only sim 1 right?) It comes with a harness and everything you need. Just plug and play guys. I'm not ******* the DIY simulator, I'm just trying to help out. It might be a more permanent fix for some folks.
http://www.jegs.com/cgi-bin/ncommerc...28&prmenbr=361
I haven't used it personally but hey if they're selling, it should work.
Old May 15, 2005 | 09:50 PM
Rydog's Avatar
so i'm getting the down pipe soon and i was just wondering exactly what the fowler is. i've never heard of this thing, so i'm just wondering what it is and what it's doing (besides the obvious answer of 'simulating the o2 sensor').
also, why exactly does the downpipe make the cel come on? does it remove the cat when it's installed?
sorry for the newbish questions, just wanna know more about it before i get it.
cheers.
Old May 15, 2005 | 10:02 PM
loctfrank's Avatar
It's a simple resistence, that return a .5 to 4.5 volts signal , if you remove it, the pcm have open circuit with O2 and make CEL light appear
You can but simple resistance( you have to know the correct value) and conect it, but it's more easy to but the little parts(don't know the name) and plug it...it's full plug and play....
FranK
Old May 15, 2005 | 10:19 PM
ralliartracer's Avatar
I did the cel fix and my light came on 2 times already, currently at the 2nd time, usually happens after about 500-800 miles. i checked and rechecked everything, all bolts tight, sensors are good. . .i dunno whats up.
Old May 16, 2005 | 06:42 AM
AlkalineTrio124's Avatar
It worked for quite some time for me... but now it's done... The fix isn't working anymore... so I'm going to have a hi-flow catalytic converter welded into the DP probably sometime in the near future!!!
