View Poll Results: Does your Lancer Ralliart got squeeks, squeels, rocks?
Squeels or squeeks (major)
29.63%
Rocks in suspension/bushing
14.81%
Ralliart is fine, man.
15
55.56%
Voters: 27. You may not vote on this poll
Squeeks, rocks or good clean shocks?
The squeeking in the rear comes from the lower control arm bushings. It only occurs in weather approximately below 0C or 32F. Mitsu is currently working on a fix as they do not have any replacements that will not squeek. If they relplace the bushings with the ones they have they will squeek the very next morning.
Apparently Mitsu is working on a fix somewhere in Quebec. Once they find a bushing that fits that does not squeek they will be replacing them. (Note: the same issue is occuring with the new Outlanders as they share the same bushings.)
The best thing to do is call your local dealership and find out when they will have a permanent fix.
Have a great day everyone!
Originally Posted by mojambo
Mike, did they do an alignment after changing the lower arms?
Car rides, tracks, and corners fine, but I'll be watching for weird wear patterns on the rear tires. I'll get the alignment checked next time I buy tires, unless I find reason to do so earlier.
I have the same problem with my rear shock...busing...!!
it's amazing, i'm very sad about that... I have to call my dealer and they will have to do somethig about that...radio can't play enough loud to cover the "skuick" sounds
Frank from QUEBEC!
Frank from QUEBEC!
i have a squeek but it's on the right front side when I put the wheel all the way to the left....
the rim/wheel scrapes the inner front fender...... i have stock height so i really don't know why it happens....
I went to my dealer yesterday and he told me that the problem comes from the six bushings at the back of our car... Apparently, water infiltrate the bushings and that's what cause that weird sound. The guy took my phone number and names and order the parts but he told me that they receive them very slowly... BTW he told me that they is no danger... only this annoying squeeks. My temporally solution is to put the beat up!!! lol
Edit: he also told me that all lancers have this problem...
Originally Posted by LancerRalliArt
The squeeking in the rear comes from the lower control arm bushings. It only occurs in weather approximately below 0C or 32F. ......
Clark
