need engine info for vortech
need engine info
got a sheet to fill out on my car. having a little trouble with some of the information and was wondering if ya'll could help me out.
this is what i don't have so far...
volumetric efficiency
compression ratio
exhaust system...stock?
heads make/model/CFM/proted
camshaft(s) make/model/duration/lobe sep
intake manifold make/model/size
crank pulley size(inch/teeth)
i haven't looked under the hood yet to see what some of the model numbers are, but not sure of the rest. any help would be great...thanks!
compression ratio
Originally Posted by importmonkey
aight, called vortech and they sent me a sheet to fill out on my car for the correct model of supercharger. having a little trouble with some of the information and was wondering if ya'll could help me out.
compression ratio
compression ratio
http://www.4x4review.com/vehicles/mi...highlights.asp
That may give some more insight... it says outlander but it's the same 4G69 Engine.
Originally Posted by DiamondWhite
2,378 cc 2.4 liters in-line 4 front engine with 87 mm bore, 100 mm stroke, 9.5 compression ratio, overhead cam, variable valve timing/camshaft and four valves per cylinder 4G69 -Unleaded fuel -Multi-point injection fuel system -13.2 gallon main unleaded fuel tank -Power: 119 kW , 160 HP SAE @ 5,750 rpm; 161 ft lb , 218 Nm @ 4,000 rpm sorry thats all i could find.
The bold is from the "sportback model". The RA has 162hp and 162lbs of torque
http://www.datoor.com/projects.html these guys are also working on a super charger for the ralliart
they also sell the accolade body kit for the ralliart i called the guy today $2500 for a new body kit front and rear bumper ,side skirts, hood and i think the evo7 wing or a slightly damaged kit (lol) for $1300 .they get four star motor sports to install it which preps cars for the canadian rally championship i didnt ask them about the supercharger if one is ready yet
