View Poll Results: would you want skunk2's
yes
12
54.55%
no
10
45.45%
Voters: 22. You may not vote on this poll
how many RA guys intrested
Old Feb 27, 2005 | 06:48 PM
lucky04's Avatar
im going to call skunk2 on monday and see if they are going to make a coilover set for the ralliart but I need a little info, does the ra and the oz have the same suspension as far as the coilovers go.
!!!!this is not a full set its just he springs and couplers not the struts!!!!
please vote
Old Feb 27, 2005 | 09:26 PM
lookslikeanevo's Avatar
^why not just use the OZ one since they sahre the same suspension?...
Old Feb 27, 2005 | 10:36 PM
0_lancer_4's Avatar
i dont think we have the same suspension similar not that same =\
Old Feb 27, 2005 | 11:05 PM
otter's Avatar
EvoM Administrator
Any spring made for the OZ will work on the RA. That said, there's already a nice set of coilover springs (just springs) for the RA made by Nex Tech. Check the vendor section.
Old Mar 3, 2005 | 06:37 AM
jdizzy's Avatar
Be careful with adjustable coil over springs on stock shocks. Go too low and the springs can be too short and will bounce around on the strut if it extends too far. Also your suspension travel will be too short and you will be bottoming out your suspension (not good for stock shocks). Another problem is that if you keep stock shocks those hard springs will have you bouncing around alot. If your roads lack bumps and pot holes you should be ok. I know all of this from experience. It can be embarrassing.
Old Mar 5, 2005 | 09:48 PM
lancerallyart's Avatar
Cool
the supension is totally not the same i would only trust tein coil if i were u
Old Mar 5, 2005 | 10:30 PM
otter's Avatar
EvoM Administrator
You're incorrect. The OZ's and Ralliarts come with the exact same springs from the factory (you can check part numbers.) Any OZ spring will work for the RA.
Old Mar 5, 2005 | 10:34 PM
Alchemist's Avatar
thank you otter. there seems to be a small difference in the springs, as the RA's springs show themselves to be about 1/2" lower. However, if you go to Tein.com and look up the s-tech springs, or SS coilover suspension, the part #s for the RA and OZ are the same.
If you want to present a request for new suspension options to a vendor, be sure to include that they're making this product for two vehicles.
