Stock exhaust hangers
Old Mar 27, 2005 | 06:21 PM
otter's Avatar
EvoM Administrator
Hey all. Just wanted to pass it on to keep an eye on your stock exhaust hangers. May or may not have to do with having an axleback (probably does, aftermarket axleback seems a bit heavier.) Had my car jacked up today to take off my snow tires/wheels, and noticed that my rear-most exhaust hanger was almost completely torn in half. Probably another week or two and it would've broken completely. Luckily I had a set of Kartboy exhaust hangers that I had, until that point, been too lazy to install. Dunno whether this is just an isolated case or not, but next time you're underneath your car, take a peek.
Plus, my exhaust doesn't bounce off the sway bar perches anymore, yay!
One last thing, if you're putting steelies onto your RA for the winter, put anti-seize around the hub! My wheels had rusted to the hub It took a lot of swearing and beating it with a BFM (BFH would've damaged the wheel) to get the front wheels off. This has never happened to me before with other cars that I ran winter steelies on.
Old Mar 27, 2005 | 06:38 PM
blk-majik's Avatar
i replaced the rear on /w an aluminum hanger. it isnt going anywhere =) and my muffler is carbon fiber and titanium...so its not like it weights more than 5lbs
Old Mar 27, 2005 | 06:52 PM
AdamRA's Avatar
I tried the kartboy exhaust hangers today they went on fine but my rrm axleback (tip) is stuck right up against the bumper had to put the stock hangers back in , I tried pretty much everything. If I knew the axleback was going to cause this nasty clanging every turn every movement I wouldn't have bought it.
Old Mar 27, 2005 | 07:52 PM
otter's Avatar
EvoM Administrator
I found that when I switched to the kartboy hangers, I had to use the other hole (upper one) on the axleback mount. Then it's at the same spot in the bumper as it would be with a stock hanger on the lower hole. Does that make any sense?
Old Mar 27, 2005 | 08:54 PM
AdamRA's Avatar
I was already using the top mount I tried everything I was so angry today. waste of money and time
Old Mar 28, 2005 | 09:41 AM
reTro's Avatar
Mine did the same thing when I replaced all my hangers with the Kartboy ones... All I had to do was bend one of the hangers down a little. Just grab the biggest hammer you can find and give it a few good wacks! Or, if you can find a long steel rod to get some leverage on it, that will work too.
Old Mar 28, 2005 | 10:17 AM
AdamRA's Avatar
Never thought of just bending the hangers down a bit. Thanks reTro
Old Mar 28, 2005 | 12:42 PM
AlkalineTrio124's Avatar
I've still got stock exhaust hangars, but when I do the CEL fix for downpipe in a couple days I will check it out & see if this is or isn't an isolated case w/ Otter... But I'm afraid it might not be... I'll see...
Old Apr 11, 2007 | 11:47 AM
gjgfrombigd's Avatar
Otter,
Okay, I know this is an old thread. Don't crack me, but how many exhaust hangers are on the '04 Ralliart? Wanting to get Poly's.
Thanks
Old Apr 11, 2007 | 11:53 AM
GHEvo8's Avatar
mine broke also, my buddy got new ones with the exaust he put on his sti, i never thought i would have a subi part on my car but they are much much stronger
Old Apr 11, 2007 | 12:35 PM
CF-Ninja's Avatar
Originally Posted by gjgfrombigd
Otter,
Thanks
otter will never crack you for searching. There is plenty of good useful information in this thread.
Old Apr 11, 2007 | 02:23 PM
otter's Avatar
EvoM Administrator
Exactly. I would've cracked you for making a new thread.
Off the top of my head, I want to say 5 hangers total. 2 for the downpipe (aftermarket not really needed here) and 3 back by the muffler. Kartboy's site should have a package deal for the Lancer hangers. 3 of the hangers are identical (look kinda like an 8) and two of them are weird, with the holes at 90* from each other.
Old Apr 11, 2007 | 03:14 PM
Thanks guys. So the kit from Kartboy that has 5 hangers, does this include the "wierd" ones?
Old Apr 11, 2007 | 07:00 PM
PR_Mivec's Avatar
they are not 'wierd' they are for the evo
evos use them all
Old Apr 11, 2007 | 07:24 PM
matute's Avatar
I bought them last month and work great. Yes the kartboy it comes with 5, 2 for the DP ( i still have them arround somewhere in my room) and 3 for the muffler
