dyno results
Old Apr 5, 2005 | 07:08 PM
  #61
MitsuRalliArt's Avatar
Lightweight 17 inch wheels with good rubber are the best compromise between being able to handle and go fast at the same time.
Old Apr 5, 2005 | 08:57 PM
  #62
lrh35's Avatar
Originally Posted by BlackLab
15" wheels fit, I'm using steelies in that diameter now for winter.
I looked around and saw that a few of you are useing 15" steelies for snow. I'm just wondering if there is a set of good 15" lightweight aluminum rims that will fit.
Old Apr 5, 2005 | 09:06 PM
  #63
Small rims for speed, bigger (yet light) rims for corners. Steelies for the drag strip are great. It's not like you need to look good. If you use the right setup, you may want to wash the rear of the car. That's the only side people should see going down the strip.
Old Apr 5, 2005 | 11:13 PM
  #64
amg_dragon's Avatar
LOL Yeah, that was my plan! 15" steelies with drag radials. I'm thinking of putting an extra coat of wax on the tail so HE can see the look on his face too!
Old Apr 6, 2005 | 07:58 AM
  #65
lrh35's Avatar
If I get the 15" steelies and performance tires I think I'll get some es hub caps and go sleeper mode.
Old Apr 6, 2005 | 09:12 AM
  #66
coote's Avatar
make sure they're the spinner hubcaps from wal-mart
Old Apr 6, 2005 | 11:34 AM
  #67
ErikT's Avatar
*sigh*
Here's how to solve all your problems. Get your car dynoed on a hydraulic dyno. Drive for show on the 18s. For racing, you might want to go with 17s. Get the 15" steelies too, just in case. Have I left anything out?
Old Apr 6, 2005 | 01:03 PM
  #68
coote's Avatar
i'm pretty sure we've all agreed on that already. i'm just gonna stick with my stock wheels for racing and dyno's and the 18's for show.
Old Apr 6, 2005 | 02:08 PM
  #69
ErikT's Avatar
^^^ Sounds good.
Old Apr 7, 2005 | 11:17 AM
  #70
bahamut's Avatar
There are factors against bigger wheels: rotaional mass, weight, affect on gear ratios, and friction/grip.
Silly example:
If Omar dynoed his car w/ 13" rims, he'll probably get +500 whp + screeching on the rollers.
On the 1/4, his car won't ever get grip on the track since it'll be busy hopping and barking all the way down the lane. Possible higher trap speed.
Old Apr 7, 2005 | 02:20 PM
  #71
mitsurally's Avatar
im running 18's and 215/35 rubber too. it felt like the car was slower after i got them put on but that doesnt really matter to me right now. my big ? is can i lower the car at all cuz it doesnt look like im gonna have enough room to clear the rear fenders inside lip can anyone help?
Old Apr 7, 2005 | 03:20 PM
  #72
coote's Avatar
you can lower it. i have the tein s-tech springs installed on my car, and i don't have any problem with rubbing at all. you should be fine. neither the progress nor the tein s-tech's lower the rear much at all. maybe half an inch at the most.
Old Apr 7, 2005 | 03:50 PM
  #73
Huscroft6's Avatar
From everyone ive heard from, 18s compared to 17's will maybe cost you 5-8WHP
Old Apr 7, 2005 | 05:10 PM
  #74
mitsurally's Avatar
how much do the progress springs lower the rear?
Old Apr 7, 2005 | 05:38 PM
  #75
coote's Avatar
the progress springs lower the rear (and the front) the same as the s-tech's as far as know. i know they don't lower the rear hardly at all...the same as the s-tech's. you'll be fine with whichever ones you get. like i said, it's only lowered like half an inch in the rear, if that.
