A'PEXi maps/settings?
Old Apr 2, 2005 | 03:47 PM
ErikT's Avatar
Hey all. I'm picking up an APEXi S-AFC and was wondering if there are any maps/settings that have been proven successful with the Ralliart. Thanks!
Old Apr 2, 2005 | 04:15 PM
ErikT's Avatar
Also, can I use to this to get rid of the speed limiter and up the revs on the rev limiter?
Old Apr 2, 2005 | 04:26 PM
otter's Avatar
EvoM Administrator
RA has no speed limiter.
Old Apr 2, 2005 | 04:41 PM
ErikT's Avatar
Really? I heard is was around 135. I know I couldn't get mine above about 133. No mods at the time.
Any info on the a/f ratios?
Old Apr 2, 2005 | 04:59 PM
otter's Avatar
EvoM Administrator
RA is drag limited. Just means that the car reaches a point where it no longer has enough power to cut through the air any faster (if you already knew that, sorry for boring you ). Make the car more aerodynamic or more powerful, then you can go faster.
You probably won't find much help on the a/f ratios. Very very few people have installed custom a/f controllers on their Ralliarts. Most have gone with pre-programmed piggybacks.
Old Apr 2, 2005 | 05:14 PM
ErikT's Avatar
Thanks, Otter. Didn't know it was the drag limiting my speed.
Old Apr 2, 2005 | 05:38 PM
Alliedcries's Avatar
I installed mine and never got it fully working. I think there is one other people that has one in their car. I had an issue due to someone telling me the wrong information on installation and just never got around to hooking it up right.
If you find something out with sensor settings or anything let me know I'd appericatre it>
Old Apr 3, 2005 | 08:55 AM
sillypuddy's Avatar
off topic.. but it's sort of bad that your sig is like 90000 lines long
-joe
Old Apr 3, 2005 | 10:33 AM
-joe
whos what?
Old Apr 3, 2005 | 11:16 AM
ski10804life's Avatar
hey im ordering my s-afc soon i when i get it and install it i will let you know, post pics and info and stuff ok
Old Apr 3, 2005 | 11:14 PM
ErikT's Avatar
I might be putting mine on tomorrow. If so, I'll let you know what we find out.
Old Apr 3, 2005 | 11:25 PM
Arithmetic's Avatar
I hope you guys get this to work, so far everybody has been comming up with NOTHING...
Old Apr 3, 2005 | 11:36 PM
ErikT's Avatar
Not encouraging. We'll see what I (translation: my mech) can do. Problem is, the results will all be subjective. I never got my stock RA dynoed, or ran any times with it. Added new front tires first. Tuned up the exhaust last weeek. Add the APEXi next. Then I'm adding intake this week also (if it arrives). My mech is going to tune it for me.... but the shop doesn't have a dyno yet. So by the time I get on a dyno I will have all three mods.
Old Apr 3, 2005 | 11:38 PM
Arithmetic's Avatar
^^^ sounds good, just keep us up to date
Old Apr 4, 2005 | 11:29 AM
ErikT's Avatar
Update: talked to a guy today who works alot with APEXi comps. Since the S-AFC is not made for the Lancer it throws a CEL about 50% of the time it is installed. MIL eliminator won't fix the problem because the issue is between the AFC and the ECU, not any sensor. So, I'm holding off until I learn more. Goodbye fuel management.
