SRI > CAI
Old Feb 22, 2006 | 11:30 AM
  #31
AzN_Enthusiast's Avatar
Hmmmm... im about to get an intake, but this argument didnt seem resolved... so what are the benefits and drawbacks of the cai and sri?
Old Feb 22, 2006 | 12:09 PM
  #32
mitsutech005's Avatar
in my opnion ger the sri
Old Feb 22, 2006 | 12:13 PM
  #33
boozeup&riot's Avatar
Get the injen CAI. If you dont like it, take the bottom half of it off and it's a SRI.
I live in Utah and thats what I did for the winter. I noticed a bit more low end torque with the CAI, but this was only when I have the AEM bypass valve OFF. with the bypass valve on the CAI felt very much like the SRI.
I agree with what others have said about SRI being more practical for the much bigger HP cars, there are a number of reasons that make them so - but for ours, at least my impression was that there was a very noticeable difference between running my injen CAI as an SRI (the lower half removed) and the full CAI with no bypass valve.
Old Feb 22, 2006 | 01:18 PM
  #34
ralliart 04's Avatar
Originally Posted by sillypuddy
Did they give you a reason why they would go SRI over CAI?
-joe
a quick and easy example , take a short fat straw and a long skinny straw, try pulling air through the both of them and see wich one allows more air flow
Old Feb 22, 2006 | 02:01 PM
  #35
Starlite Demon's Avatar
now jog in place witha paper towel roll on your mouth in a heated room and then stand next to your window with that tube and even if you want another paper towel roll with it to simulate more tubing and stick it out the window with fresh air and jog some more... lets see ur endurance. yes the tube is longer but overall its colder air. in the begining jogging in place with a short tube is fine untill the room heats up and ur temp goes up.
Old Feb 22, 2006 | 02:03 PM
  #36
i am also not gonna argue with people with a vented hood since that is a total different story
Old Feb 22, 2006 | 04:25 PM
  #37
LOL , ^^^^^ hold on , im gonna go get my speedo^^^^^^ LOL.
man it sure is a touchy subject , i geuss diffrent strokes for diffrent folks.
but i still think sri with vented hood and your good to go.
Old Feb 22, 2006 | 04:48 PM
  #38
i run sri with NO hood, had a cold air with hood. pretty noticable diffrence in the assometer, and even more at the track.
Old Feb 22, 2006 | 05:45 PM
  #39
deathsythe12's Avatar
ok , so SRI with vented hood. Thats a great idea !!!! (sarcasm is great!)So whats the $$$ total come down to if you buy the hood AND the SRI? It doesnt justify it. Now heres an interesting detail that hopefully will put all the debate to rest :
Originally Posted by kericr
When comparing an SRI to a CAI from the same manufactuer, the SRIs show a consistently higher peak HP. Examining the dyno sheets also shows that the SRIs tend to have a stronger power curve in general. But the article explains that with the SRI setups, the second run always showed a considerable drop off when compared to the first (unfortunately, they don't provide a 2nd dyno run to show how much of a difference, but the fact that it's mentioned makes me think that it ends up being not much better, if any, to the stock intake). Coincidentally, none of these SRIs has a heat shield. The CAIs in the comparison on the other hand, tend to retain their HP much better, even though they generated less on their best run vs. the SRI equivelent (for example, the Ingen SRI generated 144.1HP, their CAIs generated 140.4 and 143.7. This is consistent with all product lines in this comparison).
The CAI generates what 1hp less , but at least its consistent, the same cant be said about the SRI. Why? Cause hot air and your engine dont get along and the FACT is that the CAI keeps sending cooler air to the engine when compared to the air the SRI sends after you run the car a while. Sure you can get a vented hood , but like i said before you're just better of buying a CAI and if you're worried about floods just buy it with the bypass valve.
Edit: please dont go into: "oh , so what if i get a heat shield" , cause unless you make one , NO company currently makes a SRI with the heat shield.
Old Feb 23, 2006 | 02:50 AM
  #40
Ralliartboy's Avatar
does anyone have dyno sheets for a cai setup vs a sri setup?
Old Feb 23, 2006 | 06:12 AM
  #41
javastan's Avatar
I bought the aem sri, it uses the factory air dam to get cold air to the filter, it comes with a braket and all. I was reading one of the Import mags over the weekend (can't remember which one, I grabed a stack at Barnes and Noble and sat and read while drinking coffee.) and on a wheel dyno, SRI made less hp than CAI but didn't lose low end tourqe like the CAI's seem to.
Old Feb 23, 2006 | 09:36 AM
  #42
Ralliart_on_LSD's Avatar
blah
Old Feb 23, 2006 | 02:21 PM
  #43
AlkalineTrio124's Avatar
SRI + CF Vented hood = no problem!!!
Old Feb 23, 2006 | 04:27 PM
  #44
no hood.
Old Feb 23, 2006 | 08:25 PM
  #45
^ exactly!
