Is MIVEC oil or mechanical controlled?
Old May 26, 2005 | 06:44 PM
Arithmetic's Avatar
Exclamation Is MIVEC oil or mechanical controlled?
Reading up on some more VVT information, I remember awhile back a member said it was mechanical controlled, but I read on a site that it was oil controlled, so which one is it? If oil controlled, could not having an oil change effect the performance of MIVEC in the high cam phase?
Old May 26, 2005 | 06:52 PM
DSS_EVO's Avatar
Oil pressure controlled by the ECM. And yes if your oil is dirty enough it could **** up the MIVEC. But by that time your engine is ****ed anyhow.
Old May 26, 2005 | 07:03 PM
DEV0LUTI0N's Avatar
**** on MIVEC
Old May 26, 2005 | 07:42 PM
PR_Mivec's Avatar
oil afects performance alright... but do this little exersise...
look at the engine frontwise...
disconect the second plug at the end of the camshft.. and voila mivec no more.....
and if youre into grinding:
the frontmost plug is the one controling the cam perse.. so openup the holes of the bolts and there is your cam adjustment tried and tested works like a charm
that was free advise
Old May 26, 2005 | 07:49 PM
PR_Mivec's Avatar
this is youe engine arithmetic sorry if it bothers you
http://img202.echo.cx/img202/6720/adelanto9ed.png
Old May 26, 2005 | 07:57 PM
tuffguy's Avatar
If you have a camera and if it's not too much trouble, could you take a picture and circle the plug that you're talking about?
Doing this doesn't hurt the engine right? And it'll help to improve the mpg above 75mph, right?
Old May 26, 2005 | 08:00 PM
PR_Mivec's Avatar
look at the link i posted.. the two red circles are the adjusters..... the plug on the right of it is the one controling mivec.... never disconect that to run the car because it wont go pass 5kprm
Old May 26, 2005 | 08:13 PM
tuffguy's Avatar
Thanks. Is it the one that I circled in green?
I don't go above 5k very often, so that's not much of a concern. But I drive on the fwy a lot, and it's really hard keeping it under 75mph to keep MIVEC from kicking in. If diconnecting that cord helps me gain a few mpg, it's worth it for me.
Old May 26, 2005 | 08:15 PM
PR_Mivec's Avatar
i believe thats a temp sensor but i wont bet on it... i know by fact that is the one right next to it...
Old May 26, 2005 | 08:20 PM
tuffguy's Avatar
To the right of it, or to the left of it?
Old May 26, 2005 | 08:24 PM
PR_Mivec's Avatar
right
Old May 26, 2005 | 08:29 PM
tuffguy's Avatar
Awesome, thanks!
Old May 26, 2005 | 08:33 PM
PR_Mivec's Avatar
Originally Posted by tuffguy
Awesome, thanks!
exactly
that one engages mivec...
the red circles are the ones that have to bo bored up (not too much)
you can retard cam timing or fowarded remember to have a timing light w/ you....
Old May 26, 2005 | 08:38 PM
tuffguy's Avatar
I have no idea what any of that means or does, so I'm not gonna go anywhere near it.
Old May 26, 2005 | 08:46 PM
PR_Mivec's Avatar
...adjustable cam timing... rings any bells?
