Knocking noise on passenger side
Old Jul 15, 2005 | 12:35 PM
lysy82's Avatar
Every time I press on the gas or let go of the gas, I hear a knocking sound on the right front side. I went to a shop to check my springs but they are fine. Im taking my RA to a dealer on monday. Any ideas on what the issue is? My car is 05 with 3k miles.
Old Jul 15, 2005 | 12:46 PM
BLKRalliArt04's Avatar
For the love of God PLEASE use proper punctuation. Even if you did use it im still not sure what you are talking about, can you reword the question?
Old Jul 15, 2005 | 12:59 PM
Azure's Avatar
Originally Posted by lysy82
every time i press on gas or let go of a gas i can hear knocking sound on the right front side i went to a shop to check my springs but their fine im taking my RA to a dealer on monday any ideas what that can be my car is 05 with 3k miles
...you didn't let Vo6 touch your ECM for a cool $50, did ya?
Old Jul 15, 2005 | 01:06 PM
gregivq's Avatar
I have seen his car over the weekend. Everytime he would press the gas pedal (more than 30% from a stop) his right front wheel makes a popping sound. Something like hitting a header with a wrench.
Old Jul 15, 2005 | 01:10 PM
Azure's Avatar
Did you check the lugnuts on the wheel for proper installation? I had something similar-ish..turned out 2 nuts were farrr from torqued....:S
Old Jul 15, 2005 | 01:14 PM
ev-slo's Avatar
cv joints
Old Jul 15, 2005 | 01:15 PM
gregivq's Avatar
Good idea, altough he had the springs reinstalled at one of the professional shops. I doubt they would overlooked that.
Will check tough.
Hmmm, since they problem is still there they probably overlooked couple of things.
Old Jul 15, 2005 | 01:38 PM
WoRkZ's Avatar
Post
I have the exact same problem on my car... and it's going back to the dealer monday to have a spring replaced under warranty. It seems there was a bad batch of springs that can collapse a bit... and of course I was one of the lucky winners.
BTW: Did you know that, depending on the company, there can be a 14 to 17% variation in compression rate between two (supposedly) identical springs??? Aftermarket springs are made to tolerances of around 2 to 3%. Makes you think, doesn't it?
Old Jul 17, 2005 | 11:48 AM
lysy82's Avatar
its not springs on my car.I put Tein springs on my car like a month ago.Shop that did it said its not springs so car is going to a dealer on monday then will see what was that.
Old Jul 17, 2005 | 11:51 AM
gregivq's Avatar
^Can they void the warranty with the aftermarket springs on?
