Help With Pulley Install Please!
Old Sep 14, 2005 | 06:45 PM
justinhazard's Avatar
Exclamation Help With Pulley Install Please!
I am having trouble getting the belt tensioner to release tension... What size does the allen wrench need to be? Please help quick, Im gonna see if I can figure it out but I don't think I will.... Answer fast! Please!
Old Sep 14, 2005 | 06:47 PM
Arithmetic's Avatar
you have to have a 1/2 Drive Wrench Rachet. It's gonna stick in that box shape intrusion. your gonna pull it back towards the rear of the car.
Old Sep 14, 2005 | 06:48 PM
Thanks for answering quick, I waspulling towards the front haha. Gonna give her a try, thx
Old Sep 14, 2005 | 06:51 PM
Then whats the allen key for?
Tell me step by step please... I am an idiot
Old Sep 14, 2005 | 06:53 PM
Arithmetic's Avatar
Exclamation
There is a small hole, like the size of a pencil on the lower part of the tensioner. When you pull the tensioner back (towards the rear of the car) that hole is gonna line up with another hole behind it (it's black), ... put the allen wrench in there. Make sure you pull back very hard, its gonna be a struggle a few times. Put the alen wrench thru both holes, only far enough to lock it in place (half way)... DO NOT STICK IT ALL THE WAY THRU.
Old Sep 14, 2005 | 06:54 PM
Frozenrock's Avatar
Try this
https://www.evolutionm.net/forums/sh...d.php?t=149493
see if this helps
Old Sep 14, 2005 | 07:13 PM
Let me know where I'm going wrong here. I put the 1/2 inch drive into stock pulley (middle) and I turn counter-clockwise. The small black hole always lines up with the pulley and stays with the hole in the pulley at all times, it doesn't stay in one spot, but moves with the pulley. I pull the ratchet... Keeep pullin the ratcher, black hole keeps coming (I can always see it) I have read the instructions over and over time again but I just don't know what to do.
Old Sep 14, 2005 | 07:38 PM
Anyone? The tensioner is in the middle of the pulley correct? It fits a 1/2 drive ratchet, but the hole is supposed to be on the bottom left of the tensioner it says in the instructions, how can this be when it moves around all the time. I'm running out of time, someone read my mind and come up with a miracle, please!
Old Sep 14, 2005 | 07:49 PM
Please! I'm getting frustrated, it was only supposed to take an hour, its been almost 3.
Old Sep 14, 2005 | 08:01 PM
What happens if you put the allen key in all the way? Could I have broke something, please I want to get this over with. I already took the stock one off now... But not the right way. I just undid the bolts and slid it off.
Old Sep 14, 2005 | 08:05 PM
mojambo's Avatar
just pull the tensioner back and hold it there with your muscles.....then take the belt off of one pulley.
Old Sep 14, 2005 | 08:12 PM
DangerousDan's Avatar
It will be much harder to put the belt on but the allen wrench is unnecessary.
Old Sep 14, 2005 | 08:17 PM
mojambo's Avatar
seriously though, IF you can't do this pulley, you should not be working on your car. THis is quite an easy thing to do. Good thing is that you can't really mess anything up and you can learn like your trying to do. Some people don't event take their wheels off. Good luck, I don't mean to be harsh
Old Sep 14, 2005 | 09:50 PM
Well I got it installed. I was just spinning the crank because that also has a 1/2" ratchet spot in it. Thanks for everyones help. In the end I ended up calling Joe and he told me what to do. I knew I was doing something stupidly wrong and knew that it was probably really retarded. Oh well it's done now and now I know what the tensioner is
Old Sep 14, 2005 | 10:43 PM
blackhawkRA's Avatar
Glad to hear that you got it. Post here once you drive it a bit.
