NOS on Auto RA
Old Oct 9, 2005 | 07:02 AM
Badgerman's Avatar
NOS on Auto RA
I spoke to my shop about installing a nitrous kit on my automatic RA. I'd use it only a few times a year when I run the car at the strip so not worrided about damage to the engine. .He said he had done it on other automatics (not RAs) and everyone is happy. 50 shot would do wonders he suggested. He asked if I wanted a dry or wet system and whether I wanted button activated or rev activated.
My best run to date is 16.549 @ 84.5 mph.
Being a mere player I am here asking the experts. Words of advice on what system to install and what type of results I would get on the 1/4.
Old Oct 9, 2005 | 08:07 AM
ev-slo's Avatar
Nitrous is never GOOD for your engine,but 50 shot is not all that much compared to some people(150+), I would suggest a button. If you only wanna use it a few times at the track, i wouldn't getr rev activated because if u go to pass some out and you hit 5500, the Nitrous will kick in... my 2 cents
Old Oct 9, 2005 | 12:14 PM
otter's Avatar
EvoM Administrator
There's a big ol' thread in the NA section about nitrous on the RA's. 50 shot doesn't seem to be much of a problem. Might need to look into different spark plugs. Going higher results in timing issues and risk of damage (more risk than normal)
Old Oct 11, 2005 | 08:20 AM
GearDownSon's Avatar
I got a 50 kit for sale if your intrested prob cheaper than your shop hit me up!
Old Oct 11, 2005 | 12:47 PM
Ralli04Art's Avatar
what brand. hit me up with a pm on how much u want.
Old Oct 11, 2005 | 02:39 PM
the-kid's Avatar
You gettin dry or wet? I'd go dry so you don't worry about internals but then again 50 shot isn't that bad but id still go dry.
Old Oct 11, 2005 | 07:36 PM
WoRkZ's Avatar
Question
If there's one thing I know nothing about, it has to be NOS. What's the difference between dry and wet? Hell, I don't even know what the shots are... is it the performance of the NOS injector???
I've never cared about NOS enough to even ask about it until now...
Old Oct 11, 2005 | 07:42 PM
otter's Avatar
EvoM Administrator
I'm nowhere near an expert on NOS, but I think I've read enough about it to answer your questions.... I think.
A dry kit is when the nozzle only sprays NOS. A wet kit is when a mix of NOS and fuel is sprayed. Wet shots are supposedly better for larger shots (75+?) because they help prevent the car from going too lean.
The shots are an approximate measure of the horsepower given. A 50 shot nozzle is supposed to give a burst of power equivilent to about 50 horsepower.
Old Oct 11, 2005 | 07:44 PM
EvoJutsu's Avatar
wooot props to Auto RA
Old Oct 11, 2005 | 07:45 PM
WoRkZ's Avatar
Thumbs up
It all makes sense. I'm getting into a habit of thanking you otter... but once again, thank you.
Old Oct 11, 2005 | 07:46 PM
otter's Avatar
EvoM Administrator
I corrected my answer a bit, I was a touch off, but it's better now.
Old Oct 11, 2005 | 07:50 PM
otter's Avatar
EvoM Administrator
Stolen from ClubRSX.com
Please read first
As I see some of the same questions being asked, I decided to gather up posts from me and Az and put it here, to make it easier for people to get the info they need. Enjoy.
Running Nitrous
Nitrous oxide while in the bottle is a liquid. When the bottle is opened, it is turned into a gas and travels down the line to the solenoids. The solenoids keep the n2o in the line and bottle from going into the engine. When you "squeeze" The solenoid opens and releases the n2o from the bottle and the line to the nozzle. The jet that is in the nossle determines the amount of nitrous allowed through at a time (Shot size. Bigger hole, more nitrous. Smaller hole, less nitrous.) The nozzle is either mounted on the intake piping, intake manifold, or special plates. This is where the n2o is introduced to the engine. When n2o is heated, it will split into two parts nitrogen and one parts oxygen. When this happens, the nitrogen offers a "cooling effect" and the extra oxygen is presented to the combustion chamber. To compensate for the extra oxygen, there should be more fuel and therefore a bigger combustion leading to more power.
Wet kit vs. Dry Kit
A wet kit refers to a nitrous system which sprays nitrous and fuel from the nitrous nozzle, or uses two seperate nozzles for nitrous and fuel, while a dry kit only sprays nitrous.
Shots
Shots refer to the size jet you are running in your nitrous system. This determines the amount of hp you want to achieve. My rule of thumb is never run more than 35% of your whp. While this is not always true, to be on the safe side, this should be a good starting ground.
Type-S owners, that means 65 shot for you, and 50 shot for base owners! Note that several members are beyond these numbers already, some by as much as 50% more nitrous than the safety number suggests, so it IS possible!
WOT Switch
Wide Open Throttle switches. They have a sensor in the throttle body itself. To spray the nitrous you arm the system and put the pedal to the metal (wide open throttle). You only spray when you floor it. Some WOT switches are computer reliant and read off a wire that you tap, while others are an actual switch that you mount to the throttle body.
Octane
Octane, by definition, is the resistance to burn or detonation. The higher the rating, the slower the burn when ignited during the compression burn cycle of the piston. The higher octane allows for better control of burning for high compression engines. So we want to match the correct octane rating of the gasoline to the engine design to ensure complete burning of the gasoline by the engine for maximum fuel economy and clean emissions.
Running Nitrous on the RSX
To run nitrous on the RSX, you really don't have to do anything but buy the kit and install it. Colder plugs are recommended, but not neccesary. The RSX should be able to handle up to a 50 shot safely without doing anything special. You would have to run a wet kit on the RSX, unless it is the Venom kit. When moving up from 50 shots, that's when things will start to get a little tricky.
Common Switches & Device Controls
1) Nitrous Arm makes the system active. It arm the eletrical release of the nitrous into the intake/motor. I.E. the momentary switches like in the Fast and the Furious would not work unless this switch was on. The same is true for the wide open throttle switch like Daddy and I have.
2) A bottle heater switch activates the, usually, automatic bottle heater wrapped around the nitrous bottle. It reacts to the pressure and turns on at 900psi and shuts off at 1100psi I believe. It keeps the pressure ideal as long as it's not too hot in the car.
3) The remote bottle opener...? Opens and closes the bottle electronically with a motorized opener from a remote location.
4) The purge switch is a momentary switch (button) that release nitrous from the line between the purge solenoid and the bottle. If the bottle is closed it just releases the leftovers... (done for safety and to keep your lines clean for the next round).. If the bottle is open the purge will keep going as long as you hold the button down or run our of air pressure.. whichever comes first.
5) The purge arm switch makes the purge button active. I.E. if this is not on you can not purge.
6) An RPM Activated "Window" switch only allows a circuit to complete, (let's suppose it's the nitrous arm switch), when the motor is revving in a set RPM range - say 3500-7800RPMs in the case of the Type-S RSX as an optimal range. (3000-6800 for the base model)
NX Kit Nozzle Settings for the RSX(N/F)
35: 31/18
50: 35/20
75: 41/24
100: 52/31
A lot of useful info can also be had here:
http://www.nitrousinfo.com/
Old Oct 11, 2005 | 09:21 PM
WoRkZ's Avatar
Thumbs up
Thanks!
But you were almost smack right on the money the first time anyway. The details from the Acura forum were a nice complement though. Not that I would ever run such a strange contraption on my own engine though... At least, not until it's paid for in full...
