new magnaflow!
Old Oct 18, 2005 | 05:20 PM
zionphunk's Avatar
Question magnaflow sounds ricey??
i hooked my new magnaflow muffler this weekend and it sounds alot deeper during cruise and low speed acceleration. Ive also noticed a slight increase in acceleration while climbing into the higher rpms but while doing that it kinda sound a little ricey . Is this common with magnaflow or when you dont install a whole exhaust system ? heres some pics.
Old Oct 18, 2005 | 05:22 PM
EvoJutsu's Avatar
Yo how much was it and how easy was it to install. I dont kno fo sure but u can prolly install it in a Auto ralliart too right?
PM me about the info cause i want one
Old Oct 19, 2005 | 07:41 AM
Ralliart2004's Avatar
I have a magnaflow as well, I had the ricey issue. I went out and got an 18 inch glass pack with the same inner diameter as our stock pipe and replaced the resonator with that. I get the rice sound until the exhaust heats up which only takes a few minutes, and then it sounds just fine.
Old Oct 19, 2005 | 07:55 AM
BLKRalliArt04's Avatar
A glasspack on a ralliart and you dont get a ricey sound? Every glass pack ive heard on cars sounds like absolute crap. I have only heard them on preludes and redneck broncos.
Old Oct 19, 2005 | 08:22 AM
Works great, the longer the pack the mellower the sound, if you got a short one, it would would sound like ***, but the longer the pack the mellower the sound. I don't know how it works exactly but yeah, it's not bad at all. I'd let you hear it, but I'm not sure how I can go about that.
Old Oct 19, 2005 | 08:39 AM
jdizzy's Avatar
The glass pack probably absorbs the sound waves better then the resonator does...
I have a magnaflow muffler too and it doesn't sound ricey at all... always sounds deep...
Old Oct 19, 2005 | 02:08 PM
zionphunk's Avatar
so should i take off my magnaflow and replace it with a glasspack muffler or change the resonator? how do i do that?
Old Oct 20, 2005 | 11:08 AM
onlyjuancannoli's Avatar
is that a new model of the Magnaflow exhaust??? my brother has this one it sounds awesome, i agree it sounds a little ricey but at idle and launches it is pretty deep. did you change the tip or something?
edit:
Old Oct 20, 2005 | 02:11 PM
zionphunk's Avatar
no, i didnt get whole RRM exhaust system, but its the same muffler just in a different finish and i bought the tip seperately.
Old Oct 20, 2005 | 09:18 PM
Deltarider99's Avatar
The only reason the aftermarket exhausts sound 'ricey' is because the stock resonator is not long enough to support the extra flow from the new muffler. Even though we have a 'sport' exhaust stock, the muffler still probably has a baffle or two to quiet it down (to pass db standards, etc). If you cut out the stock resonator and replace it with a Magnaflow one, you will reduce the buzzing/high pitched sounds (commonly referred to as 'ricey').
Old Oct 21, 2005 | 08:03 AM
No, have your resonator cut out and replace the resonator with an 18 inch glasspack with the same Inner Diameter as whatever size piping you have for the rest of your system. You should be able to get the glass pack at any exhaust shop.
Old Oct 21, 2005 | 10:11 AM
zionphunk's Avatar
ooh ok i get it now. thanks guys.
