Brake Bleeding
Old Nov 7, 2005 | 05:33 PM
snowey1's Avatar
Question Brake Bleeding
I am going to install the ss braided brake lines on my RA. What issues are there with bleeding the brakes on an ABS system versus standard brakes (any special requirements or tools)? Snowey1
Old Nov 7, 2005 | 05:56 PM
Myszkewicz's Avatar
As long as you don't let the fluid level drop far enough to suck air into the master cylinder, it's pretty easy. The manual just says to start the engine to bleed the lines, but otherwise bleeding is done normally. Instead of starting with the line furthest from the master cylinder, though, start furthest from the ABS valves, so LR, RR, LF, RF.
If you let the fluid level drop far enough to suck air into the master cylinder, that's a bit more of a pain in the @ss. Just keep an eye on the fluid level, and don't let it get that low.
Old Nov 7, 2005 | 06:30 PM
snowey1's Avatar
Hey, thanks for the info, I'll watch the level. The reason I asked someone at work was saying you had to modulate the ABS to bleed them properly? It sounded like a bunch of you know what. Snowey1
smoothevo
Apr 8, 2017 08:04 PM
vipevo9
Aug 25, 2016 12:36 PM
ZeroFighter83
10
Aug 26, 2015 11:57 PM
governmule
Midwest Region
May 14, 2011 08:59 PM
xLaNcErEvOx
Mar 26, 2008 01:25 AM
