Cracking sound in front right tire
Old Nov 18, 2005 | 08:56 PM
WoRkZ's Avatar
Post
About the skeaking noise at the back: In our local Mitsubishi club, many guys have already taken their RA in for that problem... the bushings where badly designed. Some even had them changed multiple times. Cold weather and road salt seem to be the common factors. According to the local dealer, new bushings were designed and the next time anyone goes to get them replaced should be their last time. Let's hope it's true... 'cause mine have decided they want in on the party too.
Old Nov 18, 2005 | 08:59 PM
WoRkZ's Avatar
Post
Originally Posted by Myszkewicz
BUT, the noise I get from the front is not a squeak. I'm getting a knocking sound when I give it gas then let up with the clutch engaged. Happens quite often in Chicago tollway traffic jams.
This is exactly what I noticed this spring and when I went to have it fixed, they replaced the driver's side coil spring. I never heard the sound again, so they were probably right...
As I already said coutless time, in my case they said it was a collapsed spring from a defective batch. The spring collapsed only about 1/2"... it looks like that's enough to have it shift a bit.
Old Nov 18, 2005 | 11:00 PM
Myszkewicz's Avatar
Okay, but I have Progress springs in.
Old Nov 19, 2005 | 12:40 AM
amg_dragon's Avatar
You say you hear a thump when you gas it? The last time I had a car do that it was a CV joint going out. Have you looked at your boots to see if maybe it's torn and degreased? If it's not a CV joint, have your motor mounts checked out to see if you motor is moving around alot, if that's not it have the ball joints checked out. There really aren't a lot of things it could be after all..... Oh yeah, your sure it's not your tire hitting the fender well right? My 17" rubbed in the back and would occasionally hit the fenderwell if I REALLY ran over a speedbump hard, otherwise my only problem has been with rocks in the springs.
Old Nov 19, 2005 | 12:51 AM
mrcoolhandsome's Avatar
I had the same prob. The cause seemed to be pebbles getting caught in my bilsteins. Used an airgun to blow it at the dealership. Hope that might be the cure for some of your probs.
Old Nov 19, 2005 | 09:49 AM
jerseyjap's Avatar
i've got the squeaking sound as well but i still have in the summer, i took it to the dealership but they said they did'nt hear nuttin, i guess i have to go back before my warranty is up
Old Nov 19, 2005 | 02:12 PM
EvoLite's Avatar
These cars are certainly finicky in winter or during any cold weather. I hear all sorts of weird noises in the winter for the first 10 or so minutes. Once the car warms up, they all go away and everything is fine. ??????????
Old Nov 19, 2005 | 04:17 PM
Myszkewicz's Avatar
Well, all the important parts checked out fine. My CV joint boots are in good shape, no grease leaking out or anything. The joints themselves "grundled" (isn't that what it's called when you move the joint throughout it's range of motion by hand? ) just fine. Ball joint wasn't sloppy, tie rod end was good. With the springs unloaded, they still had a little tension on them, so they're not bouncing around. Swaybar and endlinks looked good and tight. While I was at it, I changed my transmission fluid again, and ran a couple new wires from the negative battery terminal to the intake manifold and head. Might not help, but can't hurt.
The only thing I found was a small pebble under the lowest coil of the LF spring. I pulled it out, but haven't driven the car yet to see if the noise is gone.
Old Nov 20, 2005 | 12:34 AM
ralliart2k4's Avatar
Winter for us is 60 degrees, so I couldn't tell ya if that's a your car thing or a RA thing.
Though when it's cold outside I certainly do more WHOOSHing then when it's warm. I love big nasty intakes
Old Nov 20, 2005 | 05:05 PM
Myszkewicz's Avatar
Well, the noise I had is gone. I drove about 170 miles today with the radio off, and I didn't hear it once.
Must have been that pebble under the spring coil.
Old Nov 21, 2005 | 12:29 PM
amg_dragon's Avatar
Good to hear that it's gone! You'd be surprised how frequently our RA's get a rock in the springs. It's a PITA but what are you gonna do?
Old Nov 22, 2005 | 12:04 AM
DangerousDan's Avatar
remember that your car is going to make more noises in the winter because in the summer the heat causes everything to expand. When it all shrinks in the winter the connections for EVERYTHING are looser than they were in the summer. Winter sucks.
EDIT: Except for the whooshing
Old Nov 22, 2005 | 12:17 AM
EvoJutsu's Avatar
i have the same problem. I have an auto RA. Whenever i take a hard left, and if the road is a little uneven. I hear this pop sound too. Someone clarify if this is normal? PM if its bad and wat would be a solution
Old Nov 22, 2005 | 09:08 AM
Myszkewicz's Avatar
Mine did that last summer, turned out to be rocks in the coil springs then, too.
Old Nov 25, 2005 | 10:34 AM
jackass's Avatar
when I turn from a full stop (left or right) i hear a crunching sound coming from the front right. It doesnt always do it and after i wash my car it doesnt do it at all. Also seems that it does it when my car is sitting for a while.
