puttin on the axelback
Old Jan 26, 2006 | 04:24 PM
redralli04's Avatar
so i got my axelback exhaust from rrm and i was wondering if you guys could tell me the best thing to do to get the old rusty bolts off, do you think some wd-40 will do the trick?
Old Jan 26, 2006 | 04:29 PM
Myszkewicz's Avatar
If that doesn't work, heat them up with a torch. Try propane at first, then MAPP gas or even oxy/acetylene if that doesn't work.
I haven't looked at mine, are they regular bolts, or studs built into one of the pipes? If they're just bolts, you could just cut them off and get new bolts.
Old Jan 26, 2006 | 07:36 PM
Ralli04Art's Avatar
impact gun. breaker baR
Old Jan 26, 2006 | 07:38 PM
CF-Ninja's Avatar
heat them up and give it a tap from a hammer.. should break it loose then you can spray some lube and take it off
Old Jan 27, 2006 | 05:46 AM
javastan's Avatar
Get a can of PB's amazing rust blaster. Spray it on the bolts and let it sit for 5 minutes, get a long wrench or a breaker bar and they will come right off. You can get this stuff at any auto parts store or menard's. It really works.
Old Jan 29, 2006 | 09:44 AM
redralli04's Avatar
So yea, i jacked the car up, used the rust spray, and tried and tried and tried but the bolts wont budge. I even stripped the one freakin bolt and it didnt move AT ALL!!! im so pissed, now i gotta take it to pep boys and blow more money that i want to save for my downpipe.
Old Jan 29, 2006 | 10:29 PM
ciclon1's Avatar
Do it the old school way, COKE (COCA-COLA ) put some COKE on the bolts , yes the drinking soda and let it set for 10 minutes .
Good luck
