fuses?
Old Feb 22, 2006 | 03:13 PM
demiz's Avatar
fuses?
new to the forum, whats up guys?
got a couple of questions to ask, first:
which fuse should i replace to get this buttom to work? i tried looking for it, but no luck.
and one more question:
is there any way to get the fog lights to turn on at the same time with driving lights? instead of one by one?
i love the look of the RA with fogs on.
thank you very much
-b
Old Feb 22, 2006 | 03:55 PM
mitsutech005's Avatar
your car is not under warranty? if not it is probably a relay not a fuse. im sure you could alter the wireing to make the foggies come on with the driving lights.
Old Feb 22, 2006 | 08:36 PM
DangerousDan's Avatar
yeah, search on the fog lights, a couple of people have tried that.
for the other thing, se attached and as follows
CIRCUIT OPERATION
The inside/outside air changeover damper motor is energized through the ignition switch (IG2). The motor is controlled by the A/C-ECU.
TECHNICAL DESCRIPTION
If the inside/outside air changeover damper motor does not operate normally, the inside/outside air changeover damper motor system may be defective.
TROUBLESHOOTING HINTS
Malformation of the inside/outside air changeover damper motor
Malformation of the A/C-ECU
Damaged harness wires or connectors
Attached Thumbnails fuses?-c101.png   fuses?-c-7c-10.png   fuses?-c-16.png   fuses?-circuit.png   fuses?-etacs.png
Old Feb 22, 2006 | 09:33 PM
demiz's Avatar
beautiful.
thanks yall, ill see what i can do
i appreciate it.
-b
