Synchro Mesh Help
Old Mar 7, 2006 | 08:37 PM
Ralli04Art's Avatar
Synchro Mesh Help
I wana put some synchro mesh in and just need to know where to pour it into pics or diagrams would be nice as well.
Old Mar 7, 2006 | 08:42 PM
Myszkewicz's Avatar
Find the clutch restrictor (or where it *was*) on the front of your transmission. Next to it, toward the driver's side, will be a bolt that says "OIL" on the head. IIRC, it's a 17mm bolt. That's the one you want, NOT the Torx head bolt next to it.
Looks like this:
Old Mar 7, 2006 | 09:15 PM
bruce988jl's Avatar
what's syncro mesh?
Old Mar 7, 2006 | 10:46 PM
Myszkewicz's Avatar
A brand of gear oil.
Old Mar 8, 2006 | 12:45 AM
Ralli04Art's Avatar
judjing from the pic i havent looked yet but will it dump oil out when i undo it?
Old Mar 8, 2006 | 03:24 AM
Joe Spingler's Avatar
Almost all manual tranny fill plugs are horizontal. That way, when oil starts to weep out during refill, you know it's full.
Old Mar 8, 2006 | 05:17 AM
Myszkewicz's Avatar
No, but like Joe Spingler said, it'll leak a little when refilling to let you know it's full. Have a pan under the hole to catch the little bit that will dribble out. The Synchromesh is nice in that regard, it doesn't stink as bad as regular gear oil, and it flows a bit easier.
Loosen the fill plug before you drain the old oil. It would really suck to drain out the old oil, only to find that the fill plug is stuck.
I use a funnel with a clear plastic extension tube on it that *just* fits in the hole for filling it.
Old Mar 8, 2006 | 07:41 AM
Ralli04Art's Avatar
so adding synchromesh to the existing oil in there isnt going to help much? i need to drain all of it and completely fill it with the synchromesh? and wheres the drain hole lol
Old Mar 8, 2006 | 07:49 AM
Myszkewicz's Avatar
Yeah, you would have to drain out the old oil first. The drain plug is accessible from the driver's side, near the back of the transmission. I'll see if I can get a pic. I was thinking about swapping back to my summer wheels/tires today.
Old Mar 8, 2006 | 08:11 AM
otter's Avatar
EvoM Administrator
Drain plug is pretty hard to miss. It's pretty big (20+mm?) and at the back driver's side of the tranny.
Old Mar 8, 2006 | 09:39 AM
MitsuJoe's Avatar
If it is Mitsu standard it is a 22/24mm I believe
Old Mar 8, 2006 | 01:39 PM
Myszkewicz's Avatar
Took a pic while I was swapping over to my summer wheels. IIRC, the bolt is 24mm.
Don't mind the salt and rust, it's everywhere up here.
Old Mar 8, 2006 | 07:40 PM
wrecked's Avatar
I did some digging on GM syncromesh. I wanted to use it in my RA. I am now leaning away from it because it doesnt have a GL rating or a weight on it. Also, 75w90 is thick like warm mollasses, while the syncromesh is more like water. I know some guys are saying that they are having no problems with it yet, but grenading my tranny after more long term use because I used oil that isnt made for our cars, and losing my warranty because of it, is to scary.
If anyone has a away to prove that it meets the GL4 rating and is a sufficient replacment for 75w90, please say so, because I still want to help improve my 1st to 2nd shifts.
Old Mar 8, 2006 | 11:43 PM
amg_dragon's Avatar
Well if you want a better 1-2 shift you don't need syncromesh you need motor mounts or one of the engine dampers currently floating around. That'll help more in my opinion.
Old Mar 9, 2006 | 07:20 AM
mitsutech005's Avatar
^ +10
