timing light
Old Mar 17, 2006 | 09:42 AM
mitsutech005's Avatar
timing light
i know i know. i used to be a mitsu tech so i should know this, but i have always used a mut 2 to check my ignition timing, and am getting tired of driving all the way back to my old dealership to check, adjust my timing. how yall checking your timing with a light since we have no plug wires? (puts on flame suit)
Old Mar 17, 2006 | 12:19 PM
amg_dragon's Avatar
WOW! I knew we had coil on ignition but I pushed that waaaaaay back in my brain untill now.... Is the ignition harness long enough to facilitate a jumper spark plug wire between the coil and plug? Now that I understand why you're asking, thanks for asking! I'd been putting off that part of the verification process.
Anyone have any ideas or positive answers?
edit: I checked an old timing light that came with the "plug top to boot" adapter for checking timing. If it's still available now... I can't say for sure, time to buddy up to an old timer, that's where I got mine in the first place (for a different car). While this doesn't help you directly, if someone else doesn't have a different answer you'll know there's at least 1 available.
Old Mar 17, 2006 | 12:40 PM
yeah without a mut 2 im stumped! oh and emanage has figured out how to controll mivec now right?
Old Mar 17, 2006 | 12:54 PM
amg_dragon's Avatar
Waiting on RPW to tell us about the mivec. You can always hit up a pawn shop and look for an old timing light w/ the adapter. Or try and find a double male to adapt any spark plug wire for a standard inductive light.
Maybe mitsiman will give us the answer today for the mivec.... It's been gnawing on my guts for over a year now. Blue box staring at me wimpering to be used like a high school cheerleader . No wait, I'm getting too old to comfortably say that anymore.... Yeah, right!
Old Mar 17, 2006 | 12:57 PM
i need to know because i refuse to drive all the way back to greenville to change my timing for my nitrous!
Old Mar 17, 2006 | 10:50 PM
amg_dragon's Avatar
How was the drive? LOL Doesn't anyone out there have another way to check timing?
Old Mar 19, 2006 | 11:27 PM
MikeDVB's Avatar
I was reading about MIVEC and I didn't see any description of electronics - just of the mechanical swapping of the cams and such...
I don't really know much about it but I'd like to know how it works as well =)
Mike
Old Mar 20, 2006 | 05:30 PM
bump
Old Mar 20, 2006 | 05:58 PM
PR_Mivec's Avatar
to read rpm from coil
we use the positive side of the plug of the coil...
with that you car make the light gun read rpm.....
Old Mar 20, 2006 | 06:00 PM
PR_Mivec's Avatar
btw you have a cam gear for that?
i mean how much are you retarding it...?
Old Mar 21, 2006 | 07:20 AM
yeah i know (meaning the cam gear) but i want something i can adjust quickly and easily, yet precisely. so i need a way to tell exactly how many degrees of retard i have.
Old Mar 21, 2006 | 12:15 PM
PR_Mivec's Avatar
but still you will need the cam gear to know were you are... the stock damper has the timing light mark so the rest is just point and tune... just dont drop it to far ~-3-4 for 100
~2 for 75, stock can handle 50 and less
Old Mar 21, 2006 | 01:52 PM
your confusing me. why do i need the cam gear. set it off the damper.
