Rrm Cold Air Intake
Old Mar 22, 2006 | 12:07 PM
demiz's Avatar
Rrm Cold Air Intake
desperately in need of help,
i got my piggy and cai yesterday, installed piggy, and im loving it
but things got a lil trickier. i installed the CAI today, and like a couple of threads that i read, i also got stuck in the plastic guards part
in complete annoyance, i just ripped a 'plastic guard' to try to fit the cai filter
and then the MAS wouldnt fit in the intake, so i had to drill it and make the whole bigger, i thought i was done but when i turned on my car, the engine rev'd for a little bit, and died. tried 3 more times, and it just slowly dies. i tried driving and i cant even go past 10mph, the car will just die. i dont know what to do, im not an expert
please help!
Old Mar 22, 2006 | 12:39 PM
MitsuSkot's Avatar
is the airflow sensor pointing the right way? There is a big arrow on it pointing the way it should. And the splash guards are just held on by push pins, shouldn't be too big of a problem. The filter is kind of a tight fit.
try taking off the battery terminals and waiting about 15-20 minutes, then go drive.
Old Mar 22, 2006 | 12:44 PM
ROCK's Avatar
please help!
Just give a call
ROAD/RACE
Old Mar 22, 2006 | 12:48 PM
demiz's Avatar
thanks to both of you for the replies.
* the air sensor is pointing the right way (up) - at least i hope its the right way.
* i unplugged the battery for 15 mins then plugged it back, then i let the car idle, and it is still the same
i called you guys a little while ago, and i was told to do these things as well
i also tighted the sensor but no help
i can hear this noise from the intake like its sucking a lot of air, but if feels like its struggling, is that normal?
thank you
Old Mar 22, 2006 | 01:28 PM
black ralliart's Avatar
please help!
When you installed the filter, did you put it on where the piping would go completely into the cone (like the end of the pipe would touch the other side of the filter)? Because I did that during installation and the car wouldn't even rev above 2K.
Old Mar 22, 2006 | 02:18 PM
demiz's Avatar
damn...i think i remember doing that, then pulling a lil bit back cuz i was afraid touching it would be bad, and ya mine wont even rev above 2k either
you think thats it? god, i so dont want to take everything back out but if thats what it takes...
what do you think?
-edit-
ohh, youre saying its NOT supposed to touch the cone?
Old Mar 22, 2006 | 02:22 PM
sweet_bucket22's Avatar
I think we need picts... lots of picts... especiall of the MAS sensor and the filter.
Old Mar 22, 2006 | 02:35 PM
what do you think?
-edit-
When attaching the filter, only get enough of the piping onto it so that you can clamp it down, so only like an inch? (can't remember it was months ago) or two of the piping is actually inside of the filter. And by inside of the filter I mean just the rubber entrance hole and however long it is. I hope that's not too confusing.
Old Mar 22, 2006 | 02:45 PM
Myszkewicz's Avatar
I had trouble getting the MAS sensor in my RRM CAI, too. It would go in the hole fine, but I couldn't get the bolt holes to line up. I just used my Dremel and took a little material off the sensor near the bolt holes. If I have to, I can pop it back out and take pics.
If the sensor isn't installed correctly, it can cause idle issues, CELs, and many headaches.
Old Mar 22, 2006 | 02:50 PM
demiz's Avatar
first of all i want to thank you all for all the replies, it is much appreciated.
BLACK RALLIART pointed out something very good
i pulled everything out and i didnt inset the intake all the way into the cone
now it is idling perfectly! thank you very much!
im giving it 15 mins to learn and do all that, then im going for a drive.
again, thank you all
Old Mar 22, 2006 | 03:01 PM
demiz's Avatar
paranoia tho,
it feels like i lost a lot of torque, is that normal?
the sound is crazy, even with stock exhaust
but feels like the car is struggling. im just a bit concerned about that
Old Mar 22, 2006 | 03:13 PM
KreepaEvoX's Avatar
Because of the way the intake works, it will rob you some horsepower down low, after 3.5k its a sweet melody of tire shredding shenanigans. Wait till the header so you can get the whole experience(and get rid of that restrictive factory cat, which makes your car puff after 4th gear)
Old Mar 22, 2006 | 03:19 PM
ralliartjapracr's Avatar
i have the AEM SRI and it came with pics for the installation! It was simple and easy took me about 20 min to install. Gonna take my car up to a dyno next month in pa will give you results in a later thread.
Old Mar 22, 2006 | 03:22 PM
KreepaEvoX's Avatar
I Want A Mr Badge!!!!!
Old Mar 22, 2006 | 03:43 PM
demiz's Avatar
it really does have a beautiful sound, but the car is still reving at idle, will it always be like this?
