torque numbers!
Old Apr 19, 2006 | 07:10 AM
amax's Avatar
torque numbers!
Does anyone know the torque values for the calipers and brackets? I'm in middle of painting my calipers, putting the first one back together. A little aprehensive to leave it up to feel for brakes.
Old Apr 19, 2006 | 07:24 AM
Ralli04Art's Avatar
usually you can do that without taking them off, but its too late for you. call ur dealership or look in the manual
Old Apr 19, 2006 | 07:26 AM
otter's Avatar
EvoM Administrator
Here ya go.
https://www.evolutionm.net/forums/sh...82&postcount=2
Old Apr 19, 2006 | 08:07 AM
amax's Avatar
never mind - found them. If anyone is interrested, it's 45 for the brackets and 32 for the calipers.
Old Apr 19, 2006 | 08:13 AM
amax's Avatar
Thanks Otter - That says 28 up to 31. I guess 1 ft/lb won't make much diff.
Old Apr 19, 2006 | 04:34 PM
Red Dragon's Avatar
Make sure you tighten them good because mine fell off!!!! next time dont take them off
Old Apr 19, 2006 | 08:56 PM
amax's Avatar
I'm not worried about them falling off. As long as you use the right torque specs. Otter, I found a post from you with the torque specs for the bracket (sometimes called knuckle). It calls for 74lbs +/- 7. Is that and the post above from a shop manual for the Ralliart? The dealership told me 45lbs but that seemed low to my mechanic friend. He thought more like 80. I also need the torque specs for the rear whole assembly. It's a smaller bolt so likely lower tque. I appreciate the help.
Old Apr 21, 2006 | 05:54 AM
Pax's Avatar
Pax
Here are the specs.
For the front disc, the calliper bracket support bolt is 74ft lb +- 7ft lb. The brake pin or (slider) bolt is 28ft lb +- 3 ft lb.
For the rear disc, the two brake pin or (slider) bolts are bolted into the support bracket, they are 32 ft lb +- 4 ft lb.
It is a good idea to grease those brake slider pins when you had them out. The brake pads are sliding on those pins. The grease got dried up after a year or two.
I didn’t see any grease on the rear brake pin bolts when I had those pins out, I put some high temperature grease on them to keep them slippery for the brake pads. I don’t know why the factory didn’t put any grease on the rear pins?
Old Apr 21, 2006 | 06:37 AM
otter's Avatar
EvoM Administrator
The stuff I gave is directly from the factory service manual
Old Apr 21, 2006 | 06:57 AM
amax's Avatar
Thanks Pax. I should really get a shop manual. By the way, they look great. I used VHT caliper paint - stuff they use at local dealership. I'll post pics when I get a chance.
