Has anything happened to your headlights?
Old Apr 19, 2006 | 04:20 PM
pinoynoskillz's Avatar
I just finished washing my car, then i vacuumed. as i vacuumed i left the car on, no ac, all doors open. this was the setting.
Alright, so i was walking around the front of the car when i noticed my driver side head light is popping out a little bit. so i opened up the hood and saw that my head light was being split apart, as if it was put in the over and were being pulled apart. The other headlight was fine though. this sucks. Think this is under warranty?
Oh, and i have eyelids on.
Old Apr 19, 2006 | 06:49 PM
bump bump bump
Old Apr 19, 2006 | 06:56 PM
otter's Avatar
EvoM Administrator
It should be under warranty as long as your milage isn't too high.
Move to a cooler climate.
Old Apr 19, 2006 | 06:57 PM
ralliart 04's Avatar
the dealer should cover that no problem, unless your eyelids had anything to with it
Old Apr 21, 2006 | 02:29 PM
removing my eyelids is going to be tought... any tips?
Old Apr 21, 2006 | 03:09 PM
Jasidus's Avatar
it took me over three hours to remove my eyelids, and that was with some help from 2 of my friends, i wont be putting them on again. I used a blade and carefully scrapped the tape off then used some goo gone to clean it up a bit.
Old Apr 21, 2006 | 07:09 PM
otter's Avatar
EvoM Administrator
A blow dryer and a bit of patience. You can have the eyelids off within 10 minutes, tape and all.
Old Apr 21, 2006 | 08:28 PM
atmsanchez's Avatar
otter how do u mean to use blow dryer i need to take of the tape of one of the eyelids and redo it, but the it is a ***** and ur theory sounds interesting to me.
Old Apr 22, 2006 | 03:04 AM
otter's Avatar
EvoM Administrator
blow dryer = hair dryer. Basically, use hot air to heat up the eyelids, which makes it easy to peel back the tape. This is how I removed mine.
Old Apr 23, 2006 | 09:35 AM
maybe ill do it on a really hot day in south florida... summer is right around the corner. haha. im going to look like a piece of cooked bacon when im done with this..
Old Apr 23, 2006 | 10:30 AM
i took my eyelids just now, along with the big pieces of 3m double sided. but all that sticky stuff is on my head lights. it's going to be a PITA to remove. i used the blow dryer also, but the 3m just wouldnt come off cleanly. more hard work for me...i just developed calouses on my finger tips. hah.
Old Apr 23, 2006 | 11:52 AM
otter's Avatar
EvoM Administrator
Some goo gone will get that off.
