She keeps stalling, what do I do?
Old May 15, 2006 | 12:25 PM
Bordelon333's Avatar
Question She keeps stalling, what do I do?
On my way home from work last night i turn a corner and my check engine light turns on. 5 Seconds later she runs rough as hell and stalls out. I try to start her and she sputters, runs rough and dies. If i feather the gas lightly she runs but is rough, if it goes above 3K she dies. I think it is the fuel pump. It was running perfectly fine minus a drop in MPG over the past month. Please help me?
Old May 15, 2006 | 01:05 PM
LeftysRule22's Avatar
not sure but id try to make sure all your intake assembly stuff is good and tight...mine did that when i forgot to put a clamp back on
Old May 15, 2006 | 01:06 PM
bluebyu36's Avatar
check your egr valve connections
Old May 15, 2006 | 01:08 PM
its all tightened up. i think it might be the piggy or the fuel pump.
Old May 15, 2006 | 01:09 PM
what is the egr valve
Old May 15, 2006 | 07:52 PM
Pikachu's Avatar
When was the last time you changed your spark plugs? It sounds like you had some misfiring. Check your cables and spark plugs. As for the fuel pump, never let your car go below the 1/4 mark before filling up. There could be a situation where by the fuel pump is left dry and thats the end of the pump....as its just a push pump.....but since you still could fire up, I dont think its the pump because when it dies, it is completely dead.......
Old May 15, 2006 | 09:21 PM
Jasidus's Avatar
this is sort of what happened with my car, something with my MAF sensor.
Old May 16, 2006 | 12:02 PM
reTro's Avatar
Check your piggy. Mine did that once when one of my wires came loose. As long as you didn't solder it on, pretty easy to pull.
Old May 17, 2006 | 01:52 PM
got it back today, it was the maf it shorted out from the piggy. so no more piggy new sensor and bam she's runnning like new again.
Old May 17, 2006 | 03:44 PM
pocoRA's Avatar
how did the MAF sensor get shorted out because of the piggy....for everyone else with the piggy could you please explain?
Old May 17, 2006 | 05:06 PM
chowetime's Avatar
seems to be a few short term problems with the piggy back - is this due to the manner it was installed - meaning did RRM install or done by the car owner... be interesting to see those that had RRM vs owners vs problems
