14829 Magnaflow muffler
Old Jul 17, 2006 | 06:01 AM
MitsuJoe's Avatar
I have a catback for sale if you want that instead
Old Jul 17, 2006 | 08:03 AM
boozeup&riot's Avatar
Mine sits at a *very* slight angle. if you're looking at the car from behind you cannot even tell. Only when you're under the car can you actually see the angle at all.
Old Jul 17, 2006 | 08:25 AM
MitsuJoe's Avatar
Go look at my custom exhaust thread and see how that sits. The muffler is angled.
Old Jul 17, 2006 | 03:36 PM
Achilles's Avatar
Mine sits at the exact same angle as yours, unnoticable.
Old Jul 17, 2006 | 03:41 PM
Ralli04Art's Avatar
you dont buy an S bend, the muffler shop has machines that make any bend they need.
Old Jul 17, 2006 | 07:35 PM
DangerousDan's Avatar
unless they can mandrel bend, which you are much less likely to stumble upon, you would be better off spending the money to get the mandrel bent kind. If you don't know the difference, do a search on mandrel bends vs press bends either on here or google.
Old Jul 17, 2006 | 08:30 PM
MitsuJoe's Avatar
Mandrel = smooth transitions that keep the diameter the same throughtout the bend. Finding a shop with a 100k Mandrel bender is like having yoru exhaust done at Magnaflow. Not likely. Most shops that will do this work will use pre-done bends.
Pressbent = less smooth transitions that bend the pipe and may reduce inside diameter on bands much over 45 degrees. Most of all exhaust shops can do this piping in house for very inexpensive.
Old Jul 17, 2006 | 09:52 PM
or you can ask Joe.
Bster13
16
Nov 13, 2008 02:39 PM
BlkLancer0211
22
Aug 26, 2005 09:19 PM
DiamondWhite
Mar 15, 2005 10:37 AM
pinoynoskillz
Feb 13, 2005 11:36 AM
statix
Nov 24, 2004 07:33 PM
