RA Question
not worth it IMO......just turbo your existing engine or get a RA and that turbo it.
You will be wasting whole bunch of $$ just for the swap that is not going to be worth the effort and $$.
wait.. what?
You're planning to drop in a 2.4L 4g69 engine into your OZ before you do the turbo? Listen, don't do it, the 2.0 has way more parts and choices to chose from. Do your research and stay with the 2.0L and boost that
+1, just stay with your current engine. A RRM stage 1 OZ can nearly hang with a Ralliart, and a stage 2 OZ is much quicker. Instead of putting money into a swap, get the stage 2 turbo, a cam, meth injection so you can run more aggressive timing. At that point you should be about as fast as a stage 1 Ralliart.
