how often do I need to change lugs?
Old Aug 18, 2006 | 11:47 AM
ddcha's Avatar
Question Rusty Lugs??
I'm running some generic chrome tuner-style lugs that came with my wheels. They're starting to rust around the edges. Even the more expensive gorilla locking lugs are starting to rust a little. Had them on through the winter. I'm wondering if I should replace them for risk of them getting stuck from the corrosion. Or is some outside rust harmless?
If necessary, I was planning on getting plain silver (not chrome) muteki lugs, which I believe are lightweight forged aluminum. So they should last longer right?
Old Aug 18, 2006 | 01:51 PM
reTro's Avatar
Well, aluminum won't rust, so I'd think so! I have Muteki lugs and have never had a problem with them. Just make sure you HAND torque them. I have to remind Discount Tire this everytime I get my tires rotated, otherwise their air tools can really jack them up.
Old Aug 18, 2006 | 05:48 PM
BudweiserJason8's Avatar
Just put some anti-seize on the studs.
Old Aug 19, 2006 | 05:10 AM
Punkskalar's Avatar
anti sieze and proper torque... You'll be fine...
Old Aug 19, 2006 | 08:56 AM
DangerousDan's Avatar
If you continue to let it rust it may stain your wheels too, I would go with some different lugs to be sure.
Old Aug 19, 2006 | 10:11 AM
ikeing's Avatar
i had my locks break one time on my rims and had to torch them off lost two rims, i would get rid of the locks ,i have also brocken a few lugs but have used antiseize ever since and have had no problems.
Old Aug 19, 2006 | 12:53 PM
ddcha's Avatar
thanks for all your advice - as always. I'll be sure to order some Muteki's
