gauge install kit
gauge install kit
Ok, here is my problem. I got the factory gauge for my RA and I want to install it. But I read a couple time there is a plug in the dash to plug it in but I can't find it. Do I need to buy a special install kit for it. If so, is it the same as the CD Changer Install Kit?
And if I want to it in the radio's place, do I also have to buy something else?
If you have a pic or 2 to show me what it's like, I would appreciate.
Thanx
Thanx
I am about to do this sort of install myself but I am making mine up as a custom job I don't know anything about a plug and play kit but to relocate the head unit to the spare din space under the air con unit you need to buy from Mitsubishi a relocation kit this will cost about $60
Then get yourself a spare headunit surround and start filling in the gap of were the old headunit used to be and then drill the hole out for the gauge using a hole saw then paint it up and should look good fit the gauges and wire them up
I think 42 draft designs have some interesting replacement parts if you are not the handy person type
