Fuel Injector/Regulator
Old Sep 3, 2006 | 12:24 AM
MITVRX's Avatar
Hey guys,
What's the purpose of having a Fuel Injector/Regulator? Like a specific description of its purpose..
Help much appreciated.
Old Sep 3, 2006 | 04:35 AM
CF-Ninja's Avatar
to regulate the amount of fuel being injected so you don't mess up your engine... Name is almost self explanatory
Old Sep 3, 2006 | 05:56 AM
otter's Avatar
EvoM Administrator
Originally Posted by MITVRX
Hey guys,
A fuel pressure regulator does just that. Aftermarket ones are adjustable, so you can change the flow for your setup, such as if you have bigger injectors. On the RA, in order to install an adjustable regulator, you must convert to a return type fuel system, which isn't too hard.
Fuel injectors are what spray fuel into the intake manifold. Upgrading those allows you to spray more fuel for engine setups that need more fuel to keep from leaning out (turbo, for example)
