Shifting from 1st to 2nd gear
I recently noticed a change in feel when I shift from 1st to 2nd gear. It's not as smooth. Kinda feels slightly clunky. No grinding noise or anything, but it just feels kinda jagged when I shift. Has anyone had a similar issue? Does my clutch need adjusting?
I notice that when I'm in first gear and let's say Im revving it higher than usual, I notice that the gear box when in first gear will start to shake/rattle a little like as if its going/wanting to move into second..
Anyone know anything...
Sorry, I was busy cleaning out another thread
A big part of the poor feel of 1-2 shifts is usually due to engine movement. We have such soft mounts, and when you combine that with how much the engine moves when in first gear, it makes for a rough feeling shift. Can be fixed by either filling your mounts or putting in a dampener.
Most economical fix is to do what I did - pull the front/rear mounts and fill them with window weld. Filling your mounts won't void your warranty.
Easiest fix is to install a dampener. While the front motor mount is really easy to remove, the rear one is a pain in the ****ing *** to get out.
Originally Posted by ddcha
I think I will go the dampener route. I've done a search and found some threads on the Northstar creations one for like $70. Some say installation was very difficult. Did RRM finally make his?
Originally Posted by tuffguy
How many times have you ground/misshifted from 1st to 2nd?
Because our engine moves so much, it's not uncommon to grind from 1st to 2nd if you change gears too quickly near redline.
I don't know if the damage is to the gears of the synchros, but I've been in a few cars that have ground 1st to 2nd that have clunky shifts.
