Removing Rubber Grommets
Old Nov 4, 2006 | 05:55 PM
MITVRX's Avatar
Does anyone know how to remove the rubber grommets that keep the stock piping inact on the hanger underneat the car..
I just can't seem to pull it off.. any ideas? Soap it? WD40 ? IDK...help
Also, that o2 sensor underneat will also be a b*tch.
Old Nov 4, 2006 | 06:46 PM
otter's Avatar
EvoM Administrator
Grease 'em and they'll come off with a bit of work. I have the polyurethane exhaust mounts, and those are a ***** to get off the downpipe. O2 sensors are easily removed with the right tools (O2 sensor socket is a must)
Old Nov 4, 2006 | 07:31 PM
MITVRX's Avatar
Yeah thanks otter, I did that, worked
Now the last of my problems before I can start installing..
If you look at that above pic, and the HFC it has an o2 sensor bolted on right... well on the stock, I have seriously tried EVERYTHING to remove that bolt.
WD-40, grease, stronger friends everything.. not working.
So I thought I'll get my electrician friend to cut the wire so the stock cat and flexipipe can come off loose and rewire them. Do you think this is a bad idea?
There is clearly 4 wires so I think it should be okay...anyone?
Old Nov 4, 2006 | 07:40 PM
otter's Avatar
EvoM Administrator
Sent ya a PM about it.
Old Nov 4, 2006 | 08:04 PM
MITVRX's Avatar
yeah lol.
Thanks otter, friends cutting the wires as we speak..
then rewiring them..
Should be sweet
I really have no choice...
