Manual transmission drain plug/fill plug help
Old Nov 6, 2006 | 06:22 PM
justinhazard's Avatar
I am changing my manual transmission fluid to royal purple and i think i have found the fill/ drain plugs... the drain plug looks like a 23mm socket and the fill plug looks like an allen key will fit in it. can anyone confirm that these are the right spots please? i don't want to mess anything up.
Old Nov 6, 2006 | 08:08 PM
Myszkewicz's Avatar
NO NO NO NO NO NO NO NO!!!!!!!
Do NOT take out the Torx head bolt, it holds your reverse gear in place. If you remove that bolt, you'll be dropping your tranny and opening it up to bolt the gear back in.
The fill plug is right next to that bolt, though, it's a 17mm bolt that says "OIL" if you look closely. I posted a pic of it in an old thread, let me see if I can dig it up.
That big one is the drain plug, though. You were right about that.
EDIT: Here's the pic of the Torx head bolt, next to the fill plug.
and here's one of the drain plug:
Old Nov 6, 2006 | 08:46 PM
Awesome thanks a lot... that would have sucked if I would've taken that bolt out haha... Thanks again man!
Old Nov 6, 2006 | 08:55 PM
12inchdriver's Avatar
wow thats cool i wanted to do the same this will help thanks
Old Nov 6, 2006 | 11:56 PM
AdamRA's Avatar
Just a for a warning royal purple will take a lot longer to warm up and you may end up with a hard to shift car for the first 5-10 minutes of driving. I have royal purple currently i'm planning on pulling it out and putting something else in.
Old Nov 7, 2006 | 08:44 AM
MitsuJoe's Avatar
And it is a 24mm for the drain plug.
Old Nov 7, 2006 | 12:53 PM
MyRoN's Avatar
Hey, what kind of oil does our tranny use, regular or synthetic
thanks
Old Nov 7, 2006 | 01:03 PM
KreepaEvoX's Avatar
I filled her up with synthethic, Mobil 1. You need 2.3 quarts to fill it according to the service manual. Something funny is that the tranny now makes a scratching noise when I shift a hard third gear, so I dont know if to recommend synth. Aside of that, which happens rarely, shifts happens reeeaaaally smoothly
I had a strage meeting with a Mitsu tech as well, when asked about filling it with regular or synth, he said " Im not to sure if its good to put synth oil in it" which left me wondering, this guys know ANYTHING AT ALL?
Old Nov 7, 2006 | 04:02 PM
MitsuJoe's Avatar
When in doubt get a fluid as good as OE.
I used the Mobil 1 Synthetic you are talking about and so far everything seems good.
Old Nov 7, 2006 | 05:33 PM
KreepaEvoX's Avatar
I guess that it is my shifting habits... I really tear her up. But that little issue I pretty much doubt it has anything to do with the tranny oil.... More like the restrictor plate for the clutch line slowing shifting action
Old Nov 7, 2006 | 08:57 PM
Myszkewicz's Avatar
That has nothing to do with releasing the clutch or shifting into the next gear, it only slows the clutch engagement. If it bothers you that much, open up the cylinder the restrictor is in, and take the springs and plastic bits out.
Old Nov 7, 2006 | 09:16 PM
MitsuJoe's Avatar
Would a RRM clutch line help this too?
Old Nov 7, 2006 | 09:27 PM
Myszkewicz's Avatar
Yeah, but that's $$. Removing a few small bits and bleeding the line only costs a couple bucks for a bottle of fluid.
europaul
Feb 19, 2017 06:11 PM
junk1337
Evo X How Tos / Installations
60
Jul 22, 2016 03:27 PM
beetle_orange
May 6, 2016 07:42 PM
ctbz860
Jul 10, 2010 07:38 PM
Methodical4u
Mar 14, 2010 05:24 PM
