CAI problem
Old Mar 15, 2007 | 04:54 PM
ralli_DC's Avatar
CAI problem
Hey everyone I just installed the CAI and after 2 days the check engine light came on. I have looked up and down this website (maybe not hard enough) trying how to figure out how to fix this. PLease help me all.
Old Mar 15, 2007 | 04:58 PM
06_RALLI///ART's Avatar
reset the ECU...disconect the battery for about 15min...should be fine...
Old Mar 15, 2007 | 05:43 PM
Realistic's Avatar
what kind of CAI do you have?
Old Mar 15, 2007 | 05:49 PM
insomniac_evo's Avatar
it'll keep coming back on, dont worry about it
Old Mar 15, 2007 | 06:49 PM
MITVRX's Avatar
It'll either going to:
1. Keep Showing
2. Not Show
3. Come and Go.
Just check that the air flow sensor is secured down properly. (not too hard). Check everything else is properly secured.
Mine only happened on the header/downpipe but thats a another story.
Old Mar 15, 2007 | 08:37 PM
k3lv's Avatar
Mine has gone on... and off... and on... and off... and on.... and off... (continues to present day).
You'll likely be running the same situation. Code usually comes out as running lean. Try to get an OBD code reader from someone(I hear people from the USA go to Autozone and they get them to check the code out for free?) and then post the code here on EvoM. It'll probably be thrown in times before and we can verify
Old Mar 16, 2007 | 05:48 PM
Myszkewicz's Avatar
I keep getting "P0171-System too lean" with my CAI and piggyback. Now that I have a laptop, I'll be getting the converter and cable I need to connect to my piggy and see if I can't tune it to prevent that.
Old Mar 16, 2007 | 06:48 PM
AdamRA's Avatar
Intresting, I've had the injen cai on for a long time and SRI for quite a while never seen a lean code or anything related to MAF. I am however plagued with the P420 code since I've got a HF CAT.
Myszkewicz : Running lean is a scary thing....better get going on that maybe your AFR is wonky.
Old Mar 16, 2007 | 07:39 PM
ralliart329's Avatar
with everything ive done i only got the light when i ran without a cat for a week. i have an injen sri and used their cai never a code.
Old Mar 17, 2007 | 05:41 PM
running lean: what bad can it do to the car???
Old Mar 17, 2007 | 07:14 PM
blkralli04's Avatar
one thing it can do, if your car runs lean it will run much hotter than it should, possibly damaging the engine
Old Mar 17, 2007 | 07:22 PM
superalf574's Avatar
i throw lean codes all the time
Old Mar 19, 2007 | 12:49 AM
how to fix this?
Old Mar 19, 2007 | 07:36 AM
Ralliart_on_LSD's Avatar
Check engine light? thats your cars way of telling you "hey im faster than stock now"
Old Mar 19, 2007 | 03:39 PM
MITVRX's Avatar
so true.
I put on the header/downpipe, now I get thrown a CEL. +1 with ROL!
