SOHC vs DOHC
Old Apr 1, 2007 | 11:04 AM
Realistic's Avatar
SOHC vs DOHC
Hey guys, I know the Evo has a Dual while our RA's have a single.. What are some of the advantages of having a Single? When I talk to my buddy (drives a supra) he tells me that the supra is better simply because its a DOHC.
I know its a rookie question.. But any thoughts?
Edit:
Is it possible to drop a DOHC into our RAs ??
Old Apr 1, 2007 | 11:17 AM
ambystom01's Avatar
Cheaper to replace all the cams in the car?
Old Apr 1, 2007 | 11:42 AM
otter's Avatar
EvoM Administrator
There really isn't an advantage to SOHC, other than timing belt changes are easier ambystom01 is right, too, one shaft is cheaper than two, but not by much.
You could also argue that there's less weight for the engine to spin, but that's a pretty weak argument. DOHC really is the better option. Finally, no, you can't convert the RA to DOHC since there's not a DOHC head out there that'll work. Plus, it wouldn't be worth the cost, since most people wouldn't take advantage of the ability to independantly set the timing on the intake and exhaust lobes.
Old Apr 1, 2007 | 01:18 PM
Realistic's Avatar
thanks otter. Someone mentioned dropping an Evo head.
whats the biggest advantage of DOHC?
Old Apr 1, 2007 | 02:17 PM
ambystom01's Avatar
It's more efficient since you have a separate cam for intake and exhaust. You can't swap an evo head in, completely different engine.
Old Apr 1, 2007 | 10:50 PM
reTro's Avatar
Don't you need DOHC to get 4 valves per cyl? I guess there a few SOHC with 24v, but I think it becomes more complicted. Also, DOHC can rev higher due to the valve/spring weights.
Old Apr 1, 2007 | 11:28 PM
ambystom01's Avatar
We have 4 valves per cylinder (we're 16v).
Old Apr 2, 2007 | 06:53 AM
otter's Avatar
EvoM Administrator
24v is for 6 cyl cars. But yes, we definitely have 4 per cylinder. If you pull the valve cover off you can see how it all works.
Old Apr 21, 2007 | 08:01 AM
mkaresh's Avatar
The advantage of SOHC is it's cheaper and makes for a more compact head.
Disadvantages:
--more complicated valvetrain, with lots of rockers and followers and such
--this means the engine cannot spin as high = lower redline
--can't have as wide an angle between the valves = less power from less spherical combustion chamber
Toyota had a DOHC two-valve engine for a while, I suppose for the third reason.
I think Honda had the first SOHC four-valve engine, in the first Legend. Since then Chrysler and Mitsubishi have also adopted the design, Chrysler only with the 3.5.
Honda appears to be the only company committed to SOHC four-valve engines, and its high performance engines remain DOHC.
