Tranny fluid change.
Old Apr 2, 2007 | 02:25 PM
Joho22's Avatar
so i wanna keep the momentum going with the car maintenance,
so next on the list for 30000 mile fun, i was thinking tranny oil.
I know im supposed to use SAE 75W-85W or 75w-90
(reading the owners manual does some magic)
so before i go forth, i know now there isnt a dipstick for my 5 speed
(thanks otter) so i was curious,
if i get my pan off, how do i get the fluid back in there?
also secondly, myself and this old motorhead i work with
have been talking about synthetic oil, and i boasted that i use mobil 1 synthetic.
we both were curious, do they make synthetic tranny fluid that would work
with the RA's? Wonder if it would be worth looking into...
Old Apr 2, 2007 | 03:05 PM
Thrice's Avatar
For the flush of your transmission oil, you don't need to remove the pan. There's a bolt to drain it and when it will be empty , you put it back on. After that, there is another bolt a little more higher on the transmission. (I think the bolts are 17mm if I'm not wrong.) Remove it. Put the oil in the whole until it flow down. Then just put the bolt were it was. Clean up the transmission with brake cleaner or something like that and enjoy you Ra.
Old Apr 2, 2007 | 03:17 PM
otter's Avatar
EvoM Administrator
There's a wonderful how-to with pictures in the Lancer how-to section.
Old Apr 2, 2007 | 04:25 PM
Joho22's Avatar
sorry, noobie doesnt know to look for those...
Old Apr 2, 2007 | 04:26 PM
Joho22's Avatar
anyone have any input or ideas on the synthetic tranny fluid?
Old Apr 2, 2007 | 09:51 PM
benny_ralliart's Avatar
im gettin my tranny fluid changed soon to since ive now hit 70k and was also thinkin about using synthetic tranny fluid, and as far as i know you can and its supposed to make shifting feel a littler "smoother" i think.
Old Apr 2, 2007 | 11:41 PM
MadMike's Avatar
I have pennzoil syncromesh in my tranny and synthetic oil works great. 2nd gear shift better when it's cold outside than with regular tranny fluid.
Old Apr 2, 2007 | 11:49 PM
moreryce's Avatar
any kind of synchro mesh will make ur shifting smoother... so get that.. im pretty sure they are synthetic.
Old Apr 3, 2007 | 05:00 AM
Joho22's Avatar
<3 thanks
Old Apr 10, 2007 | 07:19 PM
$MIVEC$'s Avatar
whats the milage that MT trany fluid needs to be serviced....my manual doesnt show any service for that :S
Old Apr 10, 2007 | 08:18 PM
AdamRA's Avatar
Originally Posted by MadMike
I have pennzoil syncromesh in my tranny.
I have that oil too and I highly recomend it. I had royal purple only for about 300 kms and it was complete garbage.
Old Apr 10, 2007 | 08:28 PM
otter's Avatar
EvoM Administrator
I haven't heard anything good about Royal Purple in our transmissions. As far as synthetics go, BG II and synchromesh are probably the only ones I'd try. Never hear anything good about the others and our transmissions.
Manual tranny service is every 30,000 miles, $MIVEC$.
