help please how to change CF license back plate
Old Apr 12, 2007 | 03:22 PM
SD Damian's Avatar
stock
CF
all i got so far now im stuck i just took out the four set screws now im wondering how to take out the lights and the plate
what do i do to get the lights out?
Old Apr 12, 2007 | 03:24 PM
ev-slo's Avatar
im doing this off memory BUT here i go...
Old Apr 12, 2007 | 03:25 PM
ev-slo's Avatar
The lights you simply turn.... then there should be a few screws then... hrm i seem to be drawing a blank... at some point there are 2 plastics like screw type thing a ma bobers... those are a ***** to get out, you gotta get a fork type tool or needle noses and PULL
Old Apr 12, 2007 | 03:26 PM
ev-slo's Avatar
the lights u need help with i think pop out as a unit... theres a clip on one side.. im better just doing it then explaining it
Old Apr 12, 2007 | 03:32 PM
SD Damian's Avatar
thanks im gonna try that right now
Old Apr 12, 2007 | 03:36 PM
Cj98's Avatar
you dont need to take out the lights if your just changing it out....theres plastic clips that hold it on and there a pita..
Old Apr 12, 2007 | 03:46 PM
SD Damian's Avatar
oooo alright ' kool cuz i just want to switch it out
Old Apr 12, 2007 | 04:45 PM
Cj98's Avatar
theres only two 10mm or 12mm nuts you have to take off and then its just plastic clips from there....is this peice the cover or a full peice?
Old Apr 13, 2007 | 04:39 AM
ralliart329's Avatar
Exclamation
i have one, its just an overlay. you take 3m tape and slap it on. i went through the whole PITA of getting it off just to find it is way to small then had to put it back on and someone else who had one told me what to do.
