Un-Friggin believable...
Old Apr 22, 2007 | 03:43 PM
Ralli04's Avatar
i cant catch a break with this car, i mean i love my RA to death but i just cant catch a d@mn break!...the weather is gorgeous out soo i decide to go and repaint my brake caliper due to chipping over the winter. soo i start to unscrew the lugnuts and im on the last one and its a little tougher to lossen than the others, well i end up getting it to budge and sure enough what happens...the lug screw ends up in two pieces, half still on the car and the other half in the lug nut..
...now mitsubishi were the last ones to have my car and put my tires on soo could this be a result of them putting it bac on too tight? and if soo is something like this covered under our warranty or do you think theyll cover it? ...it just makes me want to cry because its like everytime im going to be getting a lot of money it seems like something goes wrong with the car that makes me spend it all
Old Apr 22, 2007 | 04:26 PM
Ralli04's Avatar
what should i do?
Old Apr 22, 2007 | 04:32 PM
Q@EvoPowerMods's Avatar
no probs mang....you'll have to pull the hub off to change out the stud that broke off....the reason this happened is that the tech Overtightened the wheel with his air gun....always HAND TIGHTEN lug nuts...that way they dont get Overtorqued and this wont happen....I would contact he service manager and tell what happend it may be covered....
Old Apr 22, 2007 | 04:33 PM
2200mhz's Avatar
Yeah dude, take it back to the dealer if theyre the last ones that touched it. I mean, its not a wear and tear part so something like that should be covered. Its the tech's fault.
I sent you a PM by the way
Originally Posted by Ralli04
i
I know exactly what you mean, Ive been experiencing the same thing.
Old Apr 22, 2007 | 04:34 PM
CF-Ninja's Avatar
my brother snapped a lug on his lancer. Parts are only a few bucks he said.
Old Apr 22, 2007 | 04:39 PM
MITVRX's Avatar
That looks awful.
Let Mitsubishi have a look at it. Is that boltsnapped in half cause thats crazy. If they put it in too tight, then thats the result, probably threaded the bolt and weakened it.
Old Apr 22, 2007 | 04:43 PM
Ralli04's Avatar
^^ i think it got threaded cause it started to loosen up like the other and then it got tight as i was lossening it and then it just snapped off...im going to call them first thing tomarow morning...im supposed to be dropping the car off tuesday to have the sunroof fixed because its been getting stuck and hasnt been closing right....such bad luck
Old Apr 22, 2007 | 04:45 PM
samj601's Avatar
my lugs are always unbelievably tight. i dont know y but half of them are always really hard to take off. i wish i could afford an airgun.
Old Apr 22, 2007 | 04:47 PM
krish's Avatar
Bummer...Good thing it is an easy fix like everyone mentioned, but such an inconvenience...Crap like that happens to me all the time! I just put on new rims Thursday, took it to get it lowered slightly the next day and two of the rims got a mark on it where the guys tried to either take off or put on the wheels. So much for brand new rims
Old Apr 22, 2007 | 07:52 PM
bruce988jl's Avatar
I just switched over to my summer tires and god damned the tech at the tireshop who patched my tire tighten them so much that both me and my friend were going at the wrench and couldn't get it until finally i got it to budge after bouncing a bit on it hard.
Old Apr 22, 2007 | 07:56 PM
Kid Lancer 7's Avatar
wheel studs are like 4 buck.. this crap happened to me 2-3 times... just buy a wheel stud from mitsu.. and have them or a shop put it on u'll be fine
