what causes this? (Gas gauge problem)
Old Apr 28, 2007 | 10:03 AM
akujiki87's Avatar
Unhappy what causes this? (Gas gauge problem)
ok so yesterday i was driving home and then i notice my gas gauge dropping franticly, from half a tank to empty. then my check engine light came on. i disconnected the battery for a few min, reconnected it, my gas gauge did not move AT all. was in the position when the car is off. so i put a lil gas in it. the gauge kicked back in but then after a few min of driving dropped to E and then raised to half of a quater tank. so i filled the tank completely and now my gauge is stuck at full and wont move! what do i do?
Old Apr 28, 2007 | 03:41 PM
bruce988jl's Avatar
looks like the rocker device in your gas tank is getting stuck or something? (the device that bobs with the amount of gas in your car...)
Old Apr 28, 2007 | 05:22 PM
stEVOx's Avatar
^as above most likely, just do some 'frantic' driving(safely of course) to see if u can loosen it up
Old Apr 28, 2007 | 05:38 PM
DRFTKNGG's Avatar
Sending unit is going bad, or something has come loose interfering with the connection.
Old Apr 28, 2007 | 08:54 PM
akujiki87's Avatar
it seems good now. ill keep an eye on it now!
Old May 6, 2007 | 07:39 PM
akujiki87's Avatar
ok seems to only do it when i hit like half tank. then anything above no problem. hit half tank and it drops. then the engine light comes on...
Old May 6, 2007 | 10:58 PM
NorCal Lancer's Avatar
are you driving in the mountains or something? frequent slope changes make the needle go up and down
Old May 7, 2007 | 01:50 AM
akujiki87's Avatar
no. i mean when it hits half tank the needle drops until it hits the actual E the light comes on then the engine light. and this is flat freeway/streets.
Old May 8, 2007 | 10:04 PM
akujiki87's Avatar
i dunno whats wrong. it just does it at half tank. pissin me off....
Old May 9, 2007 | 06:46 AM
otter's Avatar
EvoM Administrator
I'm quite sure your sender is bad. Pull the sender from the tank and take a reading of the resistance while moving the float up and down. Sounds like halfway down the voltage is cutting off.
FUEL LEVEL SENSOR CHECK M1543001200557
Remove the fuel pump module and the remove the fuel level
sensor. (Refer to GROUP 13C, Fuel Tank P.13C-9.)
Fuel Level Sensor Resistance
1. Check that resistance value between terminals 2 and 1 is at
the standard value when the fuel level sensor float is
between point "F" (highest) and point "E" (lowest).
Standard value:
• Point "F": 3 ± 0.8 ohm
• Point "E": 110 ± 2.5 ohm
2. Check that resistance value changes smoothly when the
float moves slowly between point "F" (highest) and point "E"
(lowest).
3. If all checks are correct, go to fuel level sensor float height
check. If any check is not correct, replace the fuel level
sensor
Old May 9, 2007 | 07:25 AM
akujiki87's Avatar
so does that mean i just have to replace the sender? that costly?where can i find this part. ive been searching online but nothing. pls say its not a dealership only part lol.
Old May 9, 2007 | 07:41 AM
otter's Avatar
EvoM Administrator
You need to follow the instructions I posted, first. No point in replacing the sender until you're positive it's the problem.
Part number (04) MN120161
Part number (05+) MN139790
It'll run you about $90 shipped from www.mitsubishiparts.com
If you still have a warranty, then let Mitsu take care of it for you.
Old May 9, 2007 | 08:30 AM
akujiki87's Avatar
nah warrenty JUST ENDED last month....go figure..... but what will i need to run the test?(ill probably just have my uncle do it...i know nothing on how things work hehe.)
Old May 9, 2007 | 02:59 PM
otter's Avatar
EvoM Administrator
All you need is a multimeter (very useful thing to have on hand, especially if you're a homeowner.) Also need a socket set to remove the sender from the car. Should be pretty easy to get to, I think. Pull up the rear seat and there will be an access panel for it. First panel will be for the fuel pump, but there should be another one.
Old May 9, 2007 | 07:47 PM
akujiki87's Avatar
awesome thanks! ill get on it this weekend!
