tools
Old May 29, 2007 | 09:43 AM
winnnnnn2's Avatar
tools
i decided to install the mods that i purchased for my RA. (pully,intake,tie bar). but i am totally new to this.
questions:
a. what tools do i need to buy to install these mods? (Also for coilovers installations)
b. how much am i looking at?
thanks
Old May 29, 2007 | 10:15 AM
MITVRX's Avatar
For the Pulley, go here
For the Intake, you'll need:
Plyers
- to remove the plastic clips holding the splash guard
Screw driver:
- remove MAF sensor
- tighten the pod filter to the intake
- screw down the intake piping to the bracket
Any problems, PM or ring ROCK.
For the Tiebar, go here
Each one will include what tools are required. It's also best to give it a read incase for tips.
Old May 29, 2007 | 10:23 AM
19.5PSI's Avatar
go to sears....get one of those 200 piece craftmans tool set. get the 3/8 and 1/2 inch ones. that should give you the right tools for most installation. for coilovers, you'll also need a spring compressor. rent it if you can since you'll be using it for just that purposes and nothing else. get some open end wrench also, plyers, jack stands and a jack. i have one of those tool box in my trunk and it's usually enough for most of my installs.
