rrm pulley need help!!!
Old May 31, 2007 | 06:52 PM
byc_panty's Avatar
hey guys im trying to install this biach rite now n the old pulley 's four bolts seem impossible to loosen...
wat the heck?
im using a 1/2 inch but its so friken tight,...
any suggestions??
Old May 31, 2007 | 07:01 PM
MITVRX's Avatar
WD40!
Use gloves and try it again.
Old May 31, 2007 | 07:14 PM
byc_panty's Avatar
ok will try that again....damm the nut is starting to lose shape..
as well how the heck do u move the dam tensioner??
its so frekin stiff!!!
i cut my finger jus now im gettin mad!!
Old May 31, 2007 | 07:21 PM
lanzerralliart's Avatar
EvoM Super Moderator
calm down your no good working on your car all worked up....get a pipe to put on the end of the ratchet for more torque,pvc,or anything that would help....take a rest and go back to it you don't wanna F this up....
Old May 31, 2007 | 07:36 PM
byc_panty's Avatar
ok i give up...
this is gay...
im gona ask my mechanic friend..
Old Jun 1, 2007 | 05:12 AM
DangerousDan's Avatar
four bolts are turned counter clockwise. don't loosen the tension until the bolts are loose. use a 1/2" prybar for the tensioner, IIRC you should try and line the prybar up with the pulley when it's on the tensioner. That will let you get the most force on the tensioner in the direction it is supposed to go.
are you little? j/k
Old Jun 1, 2007 | 05:36 AM
drewbad's Avatar
I just loosened mine, since I have a pully on the way. 3 bolts loosened fairly easily, but the 4th I had to give a strong, powerful jerk. Otherwise the engine was spinning. Get the car up as high as possible to give yourself some room. Be sure to use jackstands. Lanzer hit it--go slip a pipe over the ratchet to give more leverage.
As for the tensioner, I dont personally own 1/2" tools, so I bought an adapter to mate from 3/8 --> 1/2 and it worked fine. I know all the instructions in the world tell you to put an allen or something in the hole to hold it back, but I dont intend to do this. I'm just going to pull it back enough to loosen and then slip the belt off.
Worstcase scenario--go buy an air rachet and a compressor if you dont have one. It sounds like you might need this in the future.
good luck to you. Take a break and a breather. Try to enjoy it, and things will go smoother!
Old Jun 1, 2007 | 05:54 AM
yep, the allen wrench is not necessary. Never used it and I have changed the belt like four times.
Old Jun 1, 2007 | 06:40 AM
Joho22's Avatar
why so often?
Old Jun 1, 2007 | 09:03 AM
outlander001's Avatar
Not necessary but will make your life easier...
Old Jun 1, 2007 | 09:08 AM
skipped around my AC and decided I wanted it back. It's the same belt RRM shipped to me and one that is shorter that I was switching back and forth. The last time I changed the belt I did it with one jackstand and a ratchet, it took all of 10 seconds or so after I could actually get to the tensioner.
Old Jun 1, 2007 | 09:39 AM
Joho22's Avatar
whew,
had me worried i was missing some sort of maitinance on the UDP...
dont do that to me...
Old Jun 1, 2007 | 06:06 PM
stEVOx's Avatar
if u cant move the tensioner with a rachet, i used a hand held vice grip type wrench and did it that way
Old Jun 3, 2007 | 07:04 PM
byc_panty's Avatar
yea maybe im a little man compared to some of yall... but nah... its the dam four bolts on my old pulley...theyre not budging at all...
im gona take it to a buddys garage this week..
will post my results afterwards
Old Jun 3, 2007 | 07:10 PM
my interweb personality is a 10 foot tall bulletbroof **** with an attitude. I'm only 5'9" and 135lb in real life I still can't see what the problem may be, you will have to let us know how you resolve this
