shifter ring
Old Jul 16, 2007 | 08:09 PM
hellview's Avatar
shifter ring
i thought i saw this on here somewere but i searched and couldnt find it.
but there was somthing about removing the ring under the shift knob and drilling or somthing.... you can reduce it by an inch?
can someone rederect me to that thread or tell me how this is done.
Old Jul 18, 2007 | 09:55 PM
hellview's Avatar
um no one?
Old Jul 19, 2007 | 09:24 AM
Cj98's Avatar
pretty much what I think your trying to say is cutting the stock shifter and then re-threading the shifter so its smaller
Old Jul 19, 2007 | 01:32 PM
hellview's Avatar
no im talking about the black plastic ring inbetween the knob and the leather
Old Jul 19, 2007 | 03:18 PM
fkdrcrs's Avatar
i really dont see how that will shorten your shifter.
Old Jul 19, 2007 | 03:57 PM
$MIVEC$'s Avatar
ive seen that post...supposedly if you remove the ring you can cut the height of the ring to the shifter then place again the knob without the ring reducing the total height a bit
Old Jul 19, 2007 | 04:02 PM
bruce988jl's Avatar
Uh... I never heard of that one. So basically you're looking for a cheap way to "lower" your shift knob.. not so much the throw of it..?
Old Jul 19, 2007 | 04:56 PM
$MIVEC$'s Avatar
exactly...makes alsmost no sense to do that
Old Jul 19, 2007 | 05:23 PM
sgand's Avatar
yeah i've heard about it being done. just take the knob, hold on tight and drill into it about an inch.
Old Jul 19, 2007 | 07:11 PM
hellview's Avatar
then wont there be a problem about screwing it back on
Old Jul 19, 2007 | 07:14 PM
Cj98's Avatar
no there wont.. theres no advantage to it what so ever
Old Jul 19, 2007 | 10:54 PM
$MIVEC$'s Avatar
maybe hes thinking it can give him a shorter throw
Old Jul 19, 2007 | 11:00 PM
AdamRA's Avatar
Buy a kartboy shifter.....I think it's a fair bit lower and the throws are short....
Old Jul 20, 2007 | 04:39 AM
bruce988jl's Avatar
+1 with Adam... Unless you really want a "low-level throwing shifter.." haha
Old Jul 20, 2007 | 05:24 AM
DangerousDan's Avatar
physics guys, physics. and really this is simple trig you should already know this when you get to physics.
this will give you a shorter throw, just not as much as moving the cable mounts on the bottom of the shifter. if you decide to drill out your shift knob you will probably destroy the threads in it and have issues mounting it back on. you can MAYBE cut a few threads off the top of the shifter, and take the ring off the bottom, to lower the shift knob. the cheapest/easiest way would be to cut and weld your shifter
