High Ralliart RPM?
Old Oct 2, 2007 | 10:16 PM
joeyj's Avatar
High Ralliart RPM?
so i just got my frist ralliart after a drunk driver totaled my old OZ, and i was wondering if the car is supposed to be a 3000rpm in 5th gear going about 70mph because my 03 oz rally didnt hit 3000rpm till like 90mph
im wondering if they previous owner did something to the car to make it do that or do all ralliart's engines rev that high?
Old Oct 2, 2007 | 10:28 PM
dimay91's Avatar
mine does :/
Old Oct 2, 2007 | 10:42 PM
egk-69's Avatar
man thats because the Ralliart Tranny its "shorter" than the OZ
(I guess shorter sounds good on spanish but not the same thing in ENGLISH!)
by shorter I mean, its close ratio!
thats all!
Old Oct 2, 2007 | 11:04 PM
joeyj's Avatar
well that's a relief
it had me worried, i thought there might have been something wrong with the tranny since it was so high.
Old Oct 2, 2007 | 11:42 PM
06RedRalli's Avatar
na its supposed to be that way...not good for gas milage on the high way but great for passing without downshifting
Old Oct 3, 2007 | 05:12 AM
fkdrcrs's Avatar
its normal, its just the car screaming GIVE ME A 6TH GEAR!!!
Old Oct 3, 2007 | 08:02 AM
joeyj's Avatar
yeah i wish it had one.
anyone here ever taken the tranny of an MR and put it into a ralliart?
Old Oct 3, 2007 | 08:12 AM
brokeazzlos's Avatar
[QUOTE=joeyj;4810561]yeah i wish it had one.
anyone here ever taken the tranny of an MR and put it into a ralliart?[/
that would be pointless
Old Oct 3, 2007 | 09:24 AM
LithiumX's Avatar
the mr tranny would be expensive
but yea the gear ratio make it so the revs are hi even for a 60 -70 gruise
you could get the fifth updated if you ever got a rebuild
Old Oct 3, 2007 | 10:19 AM
DangerousDan's Avatar
how are you guys figuring on using an AWD tranny on a FWD anyway
Old Oct 3, 2007 | 10:58 AM
Punkskalar's Avatar
I have used AWD transmissions before on a FWD application... Can work just fine as usually the rear driveline output has a viscous (sp) clutch seperate from the front driveline outputs... I usually remove the rear drive yoke, machine a cap to fit over the output shaft and call it done...
If the bellhousing mounts the same to our blocks (i think it does, Diavlo will probably know) then its completely possible...
Old Oct 3, 2007 | 11:12 AM
LithiumX's Avatar
i thought our tranny was evo minus transfer case
although i really dont know much about this stuff
Old Oct 3, 2007 | 11:25 AM
ok I see, I was under the impression everyone was assuming this was a bolt on thing... never done major work until this car, it's good to know that if the housing bolts up it's cake after that
Old Oct 3, 2007 | 11:59 AM
fkdrcrs's Avatar
there seems to be endless possibilities with the RA. i like to see new stuff like this come up. when these cars get old enough you might be surprised by what ppl have done to these little sleepers .
Old Oct 3, 2007 | 12:41 PM
joeyj's Avatar
i tried searching for this answer before i made new thread, at least there was no bashing about researching this time!
always a nice thing to see =]
