front suspension diagram
does anyone have a diagram of the front suspension? when my car is jacked up i can wiggle the wheel a little bit and i see where the problem is but i dont know what the part is called. its the little piece right next to the rotor that has a nut on the top. i just need to know what its called. thanks
You must be talking about the TieRod end, right? It has a threaded shaft going into it right? Most of the time if you can wiggle it, 9 times out of ten it is the actual tie rod. Which threads into your steering rack. If you have any questions give me a buzz.
on the topic of tie rods, does any one know where I can find inner tie rod replacements for the RA online? I've checked some places but they say it's for the 2.0L Lancers.
Edit, NM what I previously typed if you saw it.
Chances are you'll only find it at a dealer or mitsubishiparts.net.
http://www.trademotion.com/partlocat...layCatalogid=0
[C-4]PUMA
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jan 25, 2007 09:43 PM
