Threw some codes, need some help
Old Jul 31, 2008 | 04:05 PM
RalliLancerJ86's Avatar
Hey guys, was wondering if you could help me out. My CEL came on last week and was going on and off, then it stayed on. OBDII scanned it and came up with
P0137: Heated Oxygen Sensor Circuit Low Voltage
and
P0300: Random/Multiple Cylinder Misfire Detected
Did a search and found a few Evos who got the P0300 code but no real explanation of why it happened or how it was resolved.
Anyone have any ideas? The car isn't doing anything to act funny or anything like that, so I'm a little stumped. Thoughts/suggestions would be appreciated.
Old Jul 31, 2008 | 04:21 PM
otter's Avatar
EvoM Administrator
You might have a dying front O2 sensor, which could be causing a poor A/F ratio, causing knock.
Old Jul 31, 2008 | 05:42 PM
Thanks Otter. Anyway to know if thats it for sure other than replacing it?
Old Aug 1, 2008 | 06:25 AM
Eclipse2Lancer's Avatar
You can take it to a shop (likely an exhaust/muffler shop) and have it tested.
That is unless you have a high impedence DC voltmeter and can tell when you have the engine running in closed loop.
Or an oscilloscope to test how it is reacting to oxygen changes in the exhaust.
So yeah.....Otter is right......likely need to replace it.
Old Aug 1, 2008 | 01:20 PM
DangerousDan's Avatar
you don't need a scope to test the output voltages, the procedure is pretty simple and outlined in the tech manual.
Evola0
Jun 14, 2015 09:23 PM
ftlvwrx
Pacific Northwest
Sep 15, 2013 02:10 PM
djikonatx
Nov 15, 2010 05:38 AM
boostedscooby 5
21
Oct 2, 2009 02:51 PM
racer135
Sep 20, 2009 07:18 PM
